Dash Light Dimmer Circuit
Rampant
NJ
392 Hemi
Yep, that is correct.
JB1
Houston, Texas
I agree, that’s the one I use to charge my phone
Machria
Long Island
2015 Limited
Ecodiesel 3.0
So the armrest won't work then, it looks to be battery-hot. the one in the front of the console looks to be ignition-hot, that's the one you want if you want the switch lights to come on with the truck.
What do you mean by "armrest"? I'm looking for a "battery hot" lead.... ?
JB1
Houston, Texas
The power "inside" the upper console is HOT all the time, the power in the lower cubby for phone charging is HOT with ignition. Kinda depends what you want the power for and when you want it.
In my case I wanted HOT with ignition as I was only going to use this for the LED backlighting (pin 6 not pin 2)
R
reloaderguy
Oregon
2016 Power Wagon
Since I was running wires through the firewall shift linkage plate, the rotary knob power is easier to grab. I have a split bench so I'm not adding switches to the console. I may add an AEV switch pod but I'll still run the power from the rotary knob.
Machria
Long Island
2015 Limited
Ecodiesel 3.0
Yea, that ignition controlled power outlet in the cubby is ridiculous! That outlet which is there for phones obviously, should be hot all the time so you can charge a phone when the truck is off. Your not going to kill the battery charging a cell phone! I've been contemplating re-wiring that outlet so it's always hot.
JB1
Houston, Texas
I decided to bring all my wiring in from under the hood, that way I have one harness with all my wiring bundled for my AEV switch pod.
jouart
Grand Rapids Mi
2015 Laramie
Hemi 5.7 8 Speed
I couldn’t agree more. It’s on my list when the weather gets better and I have time. Did you get yours done ?
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
Fun fact, a wildly easier circuit to tap into for the dash lights is off the back of the trailer brake controller. No need to go to the other side of the dash to the headlight switch if you’re working behind the radio.
R
reloaderguy
Oregon
2016 Power Wagon
It depends on where you're mounting your switches and where you wiring originates from. My switches are mounted directly below the headlight knob.
Machria
Long Island
2015 Limited
Ecodiesel 3.0
What if you don't have a "trailer brake controller"? ;)
Machria
Long Island
2015 Limited
Ecodiesel 3.0
You still have the harness
oh, ok good point. ;)
Speaking of the "Trailer Brake controller", what does it do? I understand it has something to do with the brakes on a trailer you are pulling, but what? I saw the controller on a few trucks I looked at, and could not figure out what it did nor could any of the sales dudes tell me. It is two little knobs sticking out with a spring load between them???
Low_Sky
6.4L
Pinch knob, applies trailer brakes.
Machria
Long Island
2015 Limited
Ecodiesel 3.0
So, you "pinch" them together to apply the brakes on the trailer? That seems a bit weird, you have to take a hand off the wheel, and how do you really know how much pressure to apply...?
kad
Hudson Valley, NY
5.7L HEMI
The trailer brakes are applied automatically (and in proportion to) when you apply the truck's brakes. The "pinch to brake" aspect of the controller is for when you need to apply just the trailer brakes, which is sometimes needed to correct an instability or sway in a trailer.
-K
Machria
Long Island
2015 Limited
Ecodiesel 3.0
-K
ohhhhhhhhh! Gotcha! Thanks for clearing that up for me, always wondered that.
Reactions: kad
RedFlameRam
