- May 19, 2014
- 1,228
- 1,346
- Location
- Virginia
- 2016 Sport
- 5.7
Looks good!
Just curious how much total this all ran you? Does look great
There must be an issue with my fogs or something, because they’re nowhere near that bright.
Looks great! I already have the morimoto fogs installed. How was the install with the DDM kit?
Thanks!
How do you like the morimoto vertical fogs. Where they easy to install
so what bulbs did you use for your low beam? all of this confuses me!
I’ve got mine pointed a bit more towards the ground. I found they tend to fade if pointed straight or upward. They only produce 1200 lumen each so they don’t have much reach. They definitely work well in close vicinity spreading light both left and right. The HID’s make up for distance.
I’m sure the camera on your phone (assuming that’s what you used) has something to do with it as well. I find they exaggerate brightness a bit in night shots. But regardless, mine look nowhere near that bright. I’ll try to get a night shot for myself to compare on camera.
I can’t find them on prime anymore but this is the kit.
https://www.amazon.com/gp/aw/d/B01A...s=ddm+9005&dpPl=1&dpID=41lgx3JQQhL&ref=plSrch
this kit has the bulbs already?
