debadge
Discussion in 'Exterior' started by trentehrlish, Nov 23, 2016.
Sponsored By: BAK Factory Outlet
  1. trentehrlish
    trentehrlish Junior Member
    20
    8
    Nov 23, 2016
    Ram Year:
    2001
    Engine:
    5.9 magnum
    What do I use to get the glue off of truck after I debadge. I don't want it to take the clear coat off. Thanks
  2. trentehrlish
    20
    8
    Nov 23, 2016
    Ram Year:
    2001
    Engine:
    5.9 magnum
    What do I use to get the glue off of truck after debadging it. I don't want it to remove the clear coat on truck. Thanks
  3. Marksman
    Marksman Member
    78
    10
    Nov 14, 2014
    Ram Year:
    1999 Ram 2500 4x4 SLT
    Engine:
    V10
    I've always used rubbing alcohol on adhesive and it's worked pretty well. Wont hurt the paint either.
    Today I re-badged the truck i just bought because someone removed them...
    trentehrlish likes this.
  4. blkbaretta
    blkbaretta Senior Member
    191
    52
    Oct 7, 2012
    TN
    Ram Year:
    Engine:
    Goo Gone - works great - just clean with a little soap and water after - may not be needed, but why not?
  5. dudeman2009
    dudeman2009 Senior Member
    22
    1,395
    157
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    I've used goo gone which works pretty well. I've also used a rubber type wheel that goes in a drill to remove decals and pinstripes from vehicles when they become ratty, it also works great on tree sap, no damage to the clear coat either. I picked one up at Menards, but its something like this
    https://www.amazon.com/Follex-ERW-6-Decal-Eraser-Wheel/dp/B00BMU9CEM
  6. trentehrlish
    20
    8
    Nov 23, 2016
    Ram Year:
    2001
    Engine:
    5.9 magnum
    And just use a rag to wipe the glue away? It's thick and hard.
  7. trentehrlish
    20
    8
    Nov 23, 2016
    Ram Year:
    2001
    Engine:
    5.9 magnum
    What do I use to get it off with the alcohol. Its super hard to get off.
  8. Desert Dude
    Desert Dude Member
    81
    40
    Oct 18, 2015
    Ram Year:
    Engine:
    Goo-gone works good.
    Sent from my SM-N900T using Tapatalk
  9. quietpeen
    quietpeen Administrator Staff Member
    21,757
    1,784
    Jul 14, 2010
    Ram Year:
    2016 1500 Sport Crew Cab 4x4
    Engine:
    Eraser wheel is the no sore finger way
  10. nateinva
    nateinva Supporting Member
    625
    356
    Nov 15, 2016
    Central Virginia
    Ram Year:
    2011 1500 Laramie CC
    Engine:
    5.7L
    I did mine last weekend. Took about 1.5 hours with some stubborn adhesive.
    Initial removal with fishing line. Peeled off 75% of it by hand...the thick part. Used an eraser wheel for remaining 25%.
    Wiped everything off with goo gone, quick soapy wash and wax.
    The truck is metallic black and I have some very slight ghosting on the doors where the 1500 was. I'll get some polish over the weekend and go over it again. Love the clean look now.
Share This Page
