Decided to add a Foxbox 10" Vented Enclosure need sub opinions
TomT
SoCal/OC
Based on your amp’s specs, it’s not compatible with a 1 ohm load.
Mbrigh3
Mbrigh3
IG: Stormtrooper_5.7
MD
I'll do the 2ohm load. I'm pretty sure its currently at 4
Sent from my SM-G965U1 using Tapatalk
Chief_6.7
Update sub, amp and lc2i have been installed. I'll tune it tom. Install wore me out lol. The Foxbox arrived already sealed and assembled. Pix of installation below. Tapped off the stock alpine sub.1b969e7a2cb8c08c4e4da343b677a2e6.jpg970d58a42c4db4ded699f448836dc687.jpg89e6c134864a5a8292ad0ce549de0d44.jpg0520394cdcc185caffd1ba91af7e4181.jpgd67c140a0d1c8b20d796b5f5f59e9201.jpga50d5ab707177cb21f1dee5e175014e1.jpg
Looks great!!!!
Chief_6.7
Install looks good. I'm late to the party, but here's a pic of my foxbox with my two JL10w6v3s. I still haven't done any dynomating and definitely need to... Hell I haven't even put my driver's side back seat back in yet lol.View attachment 131845
This has gotta sound sweet...... if my one 10” sub sounds killer I can just imagine this
Jwithing
STL
I invested in an SMD DD1 and it is well worth it. Everything says amazing.
Sent from my Pixel XL using Tapatalk
Hmmm I'll have to look into this... Doesn't seem too expensive
Jwithing
STL
It really shines on SiriusXM. After 6 months of waiting for them to send me another $5/month deal to renew my 1 year subscription, I finally renewed last night. Listened to it on the way to work and had forgotten how big of a difference it made. The stubby antenna doesn't help lol.
AngryRams
Phoenix
You should check out Aaron Lewis country boy remastered by twisted something 420.. it's on YouTube I just downloaded it with videoder on my phone then put on flash drive... Its killer.
Sent from my SM-N950U using Tapatalk
Jwithing
STL
I may get crucified for this and as shocking as it may sound, there will be absolutely no country music in my truck. :D
AngryRams
Phoenix
It's not really "country music"... I mean it's hard to classify what genre
WilliamS
Tampa FL
I like their boxes, but almost $50 shipping is rough. :(
Steep but the box alone is built stout, and it will come packed pretty dang good. Mine had 2 inches of foam pellets on all sides, as well shrink wrapped.
MajMike
Panama City, FL
Should I line the inside with sound dampening material, some folks here said it really needed it?
WilliamS
Tampa FL
Jwithing
STL
Jwithing
STL
I don't think it's needed for a foxbox since it's well constructed... Others may disagree, but if a box needs sound deadening, I'd question it's construction... Unless your are pushing some monsters.
AngryRams
Phoenix
No, the JL 10W6v3 requires a minimum pole vent clearance of .5 inch which this box won't provide. They don't seem to have the box I purchased for dual 10's... Only the 12 inch version.
I sent them an inquiry about what they can come up with...
Jwithing
STL
I can't remember what the clearance was on my box. It was really tight, but seeing these numbers is making me second guess. I need to pull my JL's out and inspect them. The netaudio tall box looks like it gives much better clearance. I may have to pull the trigger and see the difference.... Would also like to hear this setup in a sealed vs. ported box.
TomT
SoCal/OC
I have a 12W6V3 in a NetAudio Tall box (sealed) and it sounds pretty great.
AngryRams
Phoenix
Yeah, I've been looking at those to. That cost though... I have some experience in fiberglass box building... I've helped my buddy make them before... Maybe I'll fool around with it before I make any decisions I'll regret.
1Popeye
