NWRQC
- Sep 5, 2011
- 842
- 87
- 2007
- 6.7 Cummins
I posted this over on their forum, but I thought that I would give it a shot here. Maybe somone can shed some light.
Diablo Predator U7137 2005 ram 1500 Hemi.
I am in the process of trying to figure out the best transmission shift points for my driving style and liking. I understand the upshift settings and have adusted them a little. The problem that I am having is understanding the downshift portion. I'm sure it's probably as easy to understand as the upshift, but I cant quite grasp it, so I am hoping that someone here can give me a hand. I found some settings online to use as a starting point and have made some adjustments to suite me.
(percentages are not the same as what the predator allows me to adjust on my truck, but close)
Upshift:
1-2 20% 1700rpm
1-2 30% 2600rpm
1-2 60% 5051rpm
1-2 80% 5351rpm
2-3 15% 1526rpm
2-3 25% 1803rpm
above raised slightly from stock
2-3 60%, 80% stock.
I am still adjusting slightly to suit my liking.... I'm good there.
Here is my confusion...Downshifts. The first RPM numbers are what the DSP displays when I click on the shift setting (i.e 2-1 @ 5%) and the second set of RPM numbers are what I found online that someone else uses (a starting point for which I was going to use).
Downshifts: stock custom
2-1 5% unsure ....... 1325rpm
2-1 80% 1503rpm .....4100rpm
3-2 45% 1603rpm ......4750rpm
3-2 55% 3000rpm ......4750rpm
3-2 75% 5150rpm .......5250rpm
So if I want the transmission to shift down a little sooner, do I adjust the first set of numbers up or down? The "online" numbers seem out of proportion compared to the stock numbers.
Right now my truck feels like it should drop down to second but holds third gear so it feels sluggish.
As an example, I was driving down the road and slowed down to make a turn on a cross street. As I turn and accelerate (say 30% throttle) the truck stays in 3rd gear instead of dropping down to 2nd. The RPM are low(say 1400rpm) so the truck feels sluggish until they get up around 1800rpm. Would I have to adjust the downshift RPM up or down.
Maybe I am searching the wrong terms, but I am finding very little on this topic (on this site and others) so any help is appreciated.
Thanks
Upshift:
1-2 20% 1700rpm
1-2 30% 2600rpm
1-2 60% 5051rpm
1-2 80% 5351rpm
2-3 15% 1526rpm
2-3 25% 1803rpm
2-3 60%, 80% stock.
Thanks
