Difference between 3.21 and 3.92 Axle Ratios
Discussion in 'Towing & Hauling' started by TruckNoob, Dec 6, 2016.
  1. TruckNoob
    TruckNoob Member
    55
    17
    Dec 6, 2016
    Dallas, TX
    Ram Year:
    Engine:
    I'm about to get a 2014 1500 LoneStar with a 3.21 Axle Ratio (sweet deal for $23,000 with 19k miles). Only problem is that it has the 3.21 axle ratio.
    Question: Does it make that much of a difference? Some charts I'm looking at are giving me a 500lb pulling capacity difference, some are giving me 2,000lbs.
    I'll own a small utility trailer dealership and although most of my trailers are delivered to me, I'll be pulling a stack of 3-4 trailers 2-3 times per month (8,000 lbs is the most I'll probably pull) on flat terrain (I'm in N. Texas).
  2. DannyMK2
    DannyMK2 Senior Member
    29
    1,723
    468
    Mar 25, 2013
    Long Island, NY
    Ram Year:
    2015 Power Wagon
    Engine:
    need more info on the truck to determine a max tow capacity. considering crew cab 4x4, 8000lbs could already be pushing it (legally). the difference in tow capacity between the two gear ratios is in fact around 2000 lbs. 3.21 to 3.92 is a big difference. whether or not its important to you, thats something your going to have to determine.
  3. TruckNoob
    TruckNoob Member
    55
    17
    Dec 6, 2016
    Dallas, TX
    Ram Year:
    Engine:
    Thanks for the response. It is a 4x2 Quad Cab w/ a 6'4" Box. I'll be using a weight distribution hitch and am looking into whether or not to put in an air bag suspension kit and the such.
    I really wish it was the 3.92, but I don't think I can pass this up at the price.
  4. thrashie
    thrashie Senior Member
    197
    64
    May 22, 2013
    Largo, FL
    Ram Year:
    2013 Ram Laramie
    Engine:
    6.7l cummins turbo diesel
    R.L.K. likes this.
  5. DannyMK2
    29
    1,723
    468
    Mar 25, 2013
    Long Island, NY
    Ram Year:
    2015 Power Wagon
    Engine:
    an 8000 lb trailer is going to put you right at max capacity. are you comfortable with that? if i had to do that 2-3 times a month, id probably re-consider my purchase.
    R.L.K., dRAMbuie and lonestar21 like this.
  6. bobeast
    bobeast Junior Member
    15
    Apr 23, 2016
    Hollister, CA
    Ram Year:
    Engine:
    Hemi 6.1
    The warm fuzzy feeling you get from finding a great price will fade long before the regret of not getting what you really want. That 2000 lb cushion is worth a few extra bucks.
    Bigdaddy and R.L.K. like this.
  7. TruckNoob
    TruckNoob Member
    55
    17
    Dec 6, 2016
    Dallas, TX
    Ram Year:
    Engine:
    You guys are killin me. I was so sold and set on that truck. Now I'm seriously reconsidering. Its now a matter of whether or not I get the 3.92 or just decide to pull smaller 6500lb loads.
    Thank you for the advice! I've been on these forums a lot the past week or two as an observer. I really look forward to being a part of the community.
    R.L.K. likes this.
  8. coldfusion73
    coldfusion73 Member
    74
    44
    Mar 28, 2013
    Ontario, Canada
    Ram Year:
    Engine:
    I have a 2016 1500 5.7 crew cab 4x4 with 8 speed and 3.21 rear. I tow a 26 ft travel trailer weighing 6000 lbs loaded with no problems.
    It tows better than my 2012 did with the 6 speed and 3.55
    UDCentaur likes this.
  9. TruckNoob
    TruckNoob Member
    55
    17
    Dec 6, 2016
    Dallas, TX
    Ram Year:
    Engine:
    Ok, while doing more research it looks like I can just get new gears put on for under $1000. Is it as simple as that?
  10. muzupan
    muzupan Senior Member
    173
    58
    Nov 23, 2015
    Raymondville TX
    Ram Year:
    2016 Ram 2500 Crew Cab
    Engine:
    Cummins 6.7
    Pulling the trailer, yes. Legally no. Legally no matter what gears you put in it the truck is still rated for the original rating. But, the truck you were looking up will pull that 8000 pound trailer with no problem even though you're at the limit. Why not shop for a 2500 and then you'll be safe all the way around. I pull a 7300 pound trailer with my 1500 with 3.21 gears, I have pulled from Georgia to South Texas with no problem. I can tell though, with handling, the truck is pushing it.
Share This Page
