DIY - add Auxiliary switches to a 2016 RAM 2500 Tradesman
Ram truck
USA
Hello I almost have the same setup as you. I just dont have the parking sensors.
Your walkthrough was great. I just need help with wiring the aux switches itself. I ordered the pins. I need to know what wires go where in the switch.
I want to keep the same harness that is on my old switch.
I want to use the new pins I have to go from new switch to the relay box.
I ordered switch 68231819AD.
Thank
rixter99
SW Arkansas
2014 3500 SRW
Cummins i6.7
I have the long male spade connectors for under the hood if anyone needs them...Won't cost you anything...I mail out sets of 5 to your address...
Ram truck
USA
I just received the switch.
Can anyone help on what pins go to the aux switches and what pins go on the towl/haul, and traction buttons.
I attached photos if the switch.
Thank you
kegger
3.6 pentastar
All I did was compair my old panel to the new one. And just added the pins to the open spots as needed.
Sent from my SM-G975W using Tapatalk
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
For those that may not know
AUX #1 and #2 are powered by the battery,
GTyankee
3.0 ecodiesel
There are several Youtube videos on how to setup the Aux. switch panel
4th Gen Electronics is mentioned, but they may have had more orders than they can handle
This guy shows how to switch out the blank buttons with marked buttons & other handy tips
The video that runs right after the first video goes into better detail & he shows how the OBDLink sets up the switch panel
Mark Moore
Marion, OH
Cummins 6.7L
Does anyone know where I can purchase the correct connectors to make my own wire harness to go from my aux switch panel to the relay/fuse box? Or is there a video out there that explains how to do it? I’ve tried to contact 4th gen electronics by email and phone to see about ordering there kit but I haven’t had any luck which from my understanding they are swamped anyhow.. thanks in advance for any help on this.. I’m amazed at the knowledge on this specific topic and I hope someone can lead me in the right direction
LarryZ
Glenville, New York
I just bought my 2015 Big Horn. I absolutely want to do this.
Questions:
*Are the actual switches removable?
*Can the switches be moved to different positions?
*I'd like to move all the current switches to the top row and make the bottom row all "Aux".
* Are the unused positions "dead-ended" in the harness?
Fishstickz
Oklahoma
'06, '16
3.7, 5.7 Hemi
Questions:
1. After watching one of the videos posted above, yeah the switches are removable with a little work
2 & 3. From the same video, it looks like it they can be moved around a little. However the top row and bottom row have different shapes to them so they may not be able to swap with each other. Also the ones on the end that curve around probably wouldn’t swap either. Also you’ll have to do some wiring to make sure the buttons you change the positions of match up with the wiring
4. It also looked like from the video that every button (including the unused boxes) have the circuitry behind it, so I would imagine those circuits have to output somewhere
Thank you to the guy who posted those videos earlier. It looks to me like the only difference in part numbers between all these switch banks is the faceplate and buttons—all the electrical appear to be there no matter the part number. Since these switches are so easy to take apart and swap buttons, I doubt it would be too hard to make some custom buttons with some fab work
Have one of you guys taken apart your old switch bank without the aux buttons? Im kinda wondering if the circuitry is behind those as well
GTyankee
3.0 ecodiesel
I recall one youtube video, where the guy changes around the buttons
You all do know that you can install the aux switches, but afterwards you have to activate it, either by going to the dealership or using a capable scan tool or programmer
Once it is activated you can use the radio to set the functions
Fishstickz
Oklahoma
'06, '16
3.7, 5.7 Hemi
You’re 100% right on a typical OEM swap, but my rig is about 7 years to old for that lol
I’m looking to put a 2013 switch bank in my ‘06. Since 2013s were hard-wired and didn’t have the LIN-bus junk, the hardest thing will be grafting it into place. Since everything is completely not-OEM anyways I’ll have a lot of freedom with the top row of buttons
GTyankee
3.0 ecodiesel
I was just referring to changing the buttons around on the auxiliary switch itself
I was not referring to the connections on the back of the switch
Mark Moore
Marion, OH
Cummins 6.7L
So when I cut my wires behind the switch bank do I connect my new wire to the side coming from the switch bank or the side running to the switch bank? Or do I connect to both
