DIY CAI and Ram air ideas
St. Charles, AR.
So I decided to make my own CAI and ram air design. The intake is made from 3" and 4" PVC. 1 90° 3" elbow, 2 3" to 4" expansions/reducers, 3" and 4" PVC. I Cut the stock intake hose right after the first bend by the throttle body, and went to 3" PVC. Then I used the reducers to open it up to 4" for about 6", and them back down to 3" to connect to a 90° from the 90° I used 3" pipe to the air filter. This is for the CAI. It's a very crude write up but I'm gonna edit tomorrow and give better instructions for the intake and ram air design. It's all prefab right now until I can finalize lol. Here's a few pics
Rusty2872
Dallas, TX
5.7L HEMI
Wow. Looks good so far. You got the part number for that filter??
PCA4208
Albuquerque, New Mexico
So what's the point in opening it up to 4" for a bit the back down to 3"? It seems it'd be simpler just to go 3" all the way. That's what I did.
WhiteBighorn12
St. Charles, AR.
My theory is that wen I stomp it, there's a but of extra air already right there beside the throttle body. Since it has less distance to travel, you get more air in the motor quicker, that would make more power. Like I said though, it's all in theory lol :D
And I will get you the # for that filter before lunch Rusty
audio1der
Airdrie, Alberta
Whitebighorn- what you have there is a W(arm)AI, not a CAI. From a stop, especially in warm weather, the engine will ingest warm air from the engine compartment. Because warm air molecules are larger and therefore less dense, you'll get less of them into the TB/Intake, thus making less power.
If you could find a way to isolate the filter from the engine compartment it could be considered a CAI.
Experimenting with the full 3" and 3"-4"-3" section between the filter and TB would be an interesting read, all else being equal, to find any benefits.
mudjunky
rusagonis new brunswick
they used that concept on old civic intake it actualy works like a charge pipe kind like the vortex box on the 5.7 vortex in the chev just to prove how well those work I dragged a tree with the box installed on my suburban I removed the box and truck could barely hall the same tree
I should in theory help in bottom end torq id almost wanna try it out with something like and 5 inch chamber
12hemi
Bradenton, FL
2012 Ram 1500 Express
That 4" section may help you a little bit on the initial pull but in the long run it could slow down the intake because of that same vortex created in the tube. its going to swirl in the larger opening making it harder for the engine to intake the air. Awesome for hauling or pulling out trees. But the top end may suffer. I would suggest (if it were possible) getting the chamber a little closer to the TB.
DILLIGAF
Canada
You forgot to add the Throttle body spacer ! Thats how you unlock the true power of a CAI....
Tray Burge
On the porch
Like the idea, but seems like it'd be suck'n nothing but hot air from there?
