Dodge ram spec charts and wiring
Discussion in 'Tech Info' started by KGBIGCOUNTRY, Apr 7, 2012.
  1. KGBIGCOUNTRY
    KGBIGCOUNTRY Senior Member
    30
    13,314
    382
    MECH, VA
    Ram Year:
    2004 RCSB/2005 QCSB
    Engine:
    5.7 / 5.7
    Full line wiring along with all the specs for your ram. Its a PDF file that you click through to find your year along with any info your checking for.
    http://www.rambodybuilder.com/year.pdf
  2. 03MopaRamman
    03MopaRamman Senior Member
    3,578
    179
    Jul 3, 2010
    Southern Alberta
    Ram Year:
    2003 Forgottens
    Engine:
    Hemi 5.7 (1 of 2)
    Maybe this will help me figure the final hook-up for my heated 05 Laramie seats which will work with some 07 switches already installed in the dash. I can use a heat pointer thingy from work and shoot at the seat to tell if the high or Low heat is on with regards to the switch single or double light...make sense? For those who have leather and drive when its -40 can relate as to how compfy it can be and also great anytime if your back is sore.
    Will have a look, thanks.
  3. KGBIGCOUNTRY
    30
    13,314
    382
    MECH, VA
    Ram Year:
    2004 RCSB/2005 QCSB
    Engine:
    5.7 / 5.7
    Hope it will help ya Danny, I ran across it earlier looking for wiring for an 06 vs 07 tails
  4. Texasez
    Texasez Senior Member
    616
    27
    Aug 25, 2012
    Dallas tx
    Ram Year:
    Engine:
    Thanks for posting. That will be helpful.
  5. Rherman1
    Rherman1 Senior Member
    56
    407
    37
    May 9, 2014
    Sunny Florida
    Ram Year:
    Engine:
    It takes me to the 2015 truck Ram build thread.
    I would like to see the 2014 build sheet.
  6. Outdoorsman1500
    Outdoorsman1500 Junior Member
    32
    Apr 6, 2015
    Fredericton, New Brunswick
    Ram Year:
    Engine:
    Hemi 5.7 V8
    Im trying find the wiring diagram and cut away pictures so I can install a backup camera mirror. (need to fins the Power, Ground, & Backup signal all under the dash for my install)
    I looked through this PDF on the 2014 1500 series and its only giving me the technical specs that the wires and fuses can handle, not the full line wiring...
    know of anywhere else I can find what Im looking for?
  7. DocHoliday
    DocHoliday Supporting Member
    168
    20
    May 9, 2015
    Las Vegas
    Ram Year:
    2014 Sport
    Engine:
    Did anyone every answer? I would love to get wiring diagram for the 2014 - 1500 - for the body harness
  8. 1500ram12
    1500ram12 Senior Member
    2,482
    325
    Jan 23, 2012
    Ram Year:
    Engine:
    6.4L Hemi
  9. DocHoliday
    168
    20
    May 9, 2015
    Las Vegas
    Ram Year:
    2014 Sport
    Engine:
    ok, the link doesn't work just like that- but I did find out you need adobe SVG Viewer and then you need to setup an account and then you pay 35.00 for 3 days or 250.00 for a month- its not free and it doesn't just work cause you click on it :(
    I paid, setup my account and then download a whole bunch of stuff and now it works, maybe someone should post all of how to do this? It took me 2 hours to get it all right, so I can try, but I don't want to give bad directions, anyone really good at how to get setup on techauthority.com?
    GWRam likes this.
  10. Virginia1987
    Virginia1987 Junior Member
    Sep 3, 2016
    Ram Year:
    Engine:
    6.7
    Hello, I just replaced the ignition starter switch in my 2011 dodge ram 3500 Cummings turbo diesel. I was having issues with the old one for example difficulty starting, shut off randomly, and complete failure to start up. Unfortunately now the new one does not start the engine, any ideas on how to fix or troubleshoot this?
Share This Page
