Dome light
Truckman73
Anyone know any tricks for getting the dome light to work. It stays on all the time. Have to remove the bulb and the map light works with the doors so I don't think it's the door switch
crazzywolfie
under the truck
have you turned the dimmer switch until it clicks? usually it is that or a door jamb switch.
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
Did you find out the issue ???
chithead
Concord,NC
2019 Ram Laramie Black
5.7L HEMI
Same here, our 88 W250, dome light stays on all the time.
SYKRAMMAN
Banned
Jersey shore
06 Mega
My 02 pos did the same thing, it was the dash switch. 60$ and 15 min all better.
crazzywolfie
under the truck
i bet someone stuck the wrong bulb in the socket. the dome lights require a special bulb that gets its ground from the wires instead of through the casing. you need a 1004 bulb. you will likely have to order one in since i don't think many if any stores would keep one in stock.
