Door lock Actuator
Viper21700
Woodbridge VA
98 CTD 12 Valve- Half the valves, twice the fun
Ok gents,
Anyone know where to get the passenger side actuator for the rams? My 98's electric door lock stopped locking the door on that one side. I can hear the motor, but its not locking the door anymore. How hard are they to change as well?
Also anyone have an extra factory stereo/cd/tape deck that works they want to get rid of? My volume has about gone the way of the dodo.
Needaram
SE WI
My gf does but youd have to buy it.
txbass06
NE Texas
5.9 Magnum
If I remember right, roll the window up, pull the door panel and it's 3 bolts and the connector and it's out
the codes
Houston, Tx
Magnum 5.2
I got a universal actuator on both doors I'll try to get you a pic. my passenger one messed up so I gotta redo it
Tapatalk Addict
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
All of the above. Pretty easy to access. I've had my door panel of several times and seent he little booger. But it will be fun getting it to come out the holes in the door. Gonna almost need noodle arms sometimes. lol
the codes
Houston, Tx
Magnum 5.2
I can verify this statement hah
Tapatalk Addict
DukeCity
Rio Rancho NM
Magnum 5.9
I have changed mine before and got used ones off eBay. They were out of a neon and much cheaper than the ram ones and the were the exact same ones
dannytas
Pioneer, CA
Here's an update on my door lock actuator: I finally had a little time to burn so I took out the door latch. Non eventful. Disconnected the 4 actuator arms, unplugged the wire harness and unscrewed the 3 tork bolts. When I connected the door lock switch and applied power, I could hear the motor work, but it wasn't moving the lock arm. So I sprayed carb cleaner on the unit and cleaned all the gunk off. Then reconnected the lock switch and activated...it worked. Then I put it all together and it still worked. So before you spend the bucks for a new power door lock latch, take it out and clean it, it just might save you money. :)
HolyRamBatman
Deep in the Heart of Texas
Sometimes it's that easy.
BruceTheLoveTruck
5.2 Magnum V8
I got one from the Dodge dealer for like $4. They are really cheap. I had a car audio company put it in for me because they were installing speakers anyways
