Door panel clip swap
neonhomer
Volusia County, FL
So, this is the first vehicle that the door panel retaining clips are a PITA to get out.
I need to order some new ones for my 99 Ram, but I was wondering if the clips that are used on the Jeep ZJ would work? They are the same plastic, but are easier to pull out compared to the stock Ram ones...
Also, what a good way to reglue the water barrier back to the door frame?
jessyj
abbotsford, bc
Just tape it back on. As far as door panels go, you need the proper tool for removal, then it,s easy.
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
Water barrier, I generally remove or use strong sticky duct tape, not the cheap $3 roll.
For the trim clips I bought some white ones on amazon 50x for $7.99 I want to say. I use them on all vehicles that I need something but they were made for the ram lol
neonhomer
neonhomer
Volusia County, FL
I picked up some of the original style ones on eBay, and some that were for my Jeep as well. The idea was to make the panel easily removable without having to replace clips.
I bought the tool as well, so I think I will just use the original clips. I don't want to put the door back together yet, as I want to swap the door speaker out before I do.
Gr8bawana
6.7 CTD
Maybe you can find some clips for older vehicles that were made of metal that were meant to be re-used over and over.
