DTC help, please
Discussion in 'Engine and Performance' started by Truemagnum15, Mar 5, 2017.
Sponsored By: Moe's Performance
  1. Truemagnum15
    Truemagnum15 Junior Member
    28
    Oct 26, 2016
    Washington State
    Ram Year:
    1999
    Engine:
    5.9L
    We have a 1999 Dodge Ram 1500 automatic 360 V8. The scan tool gave my husband two codes. We would greatly appreciate any help deciphering them.
    First code is PO138 and says 02 Sensor circuit high voltage (Bank no. 1 sensor sensor no. 2)
    Second code is P1391 and says Intermittent loss of CMP or CKP signal.
    Thank you for your time.
  2. Jrjohnson1969
    Jrjohnson1969 Junior Member
    Feb 18, 2017
    Ram Year:
    2006
    Engine:
    5.9 common rail
    The 1391 code is the camshaft sensor. I have seen a lot of posts on another site about having to change out the distibutor to get the code to go away. I'm guessing the cam sensor is in the distributor. If the cam sensor and/or distributor are replaced and still have code cone back, it could also be the crankshaft position sensor. The oxygen sensor should be after the catalytic convertor since it says sensor 2. Hope this helps you some.
    Truemagnum15 likes this.
  3. Truemagnum15
    28
    Oct 26, 2016
    Washington State
    Ram Year:
    1999
    Engine:
    5.9L
    Thank you very much
Share This Page
