Dual Battery & large alternator
Discussion in 'Dodge Ram Power Wagon' started by hbleconey, Dec 5, 2017.
  1. hbleconey
    hbleconey Junior Member
    37
    24
    Apr 30, 2016
    Ram Year:
    Engine:
    while i was down in baja we had pretty gnarly pull out of some deep clay and the winch actually hit the PW kill switch on my engine battery. Given that, i'm going to install a dual battery and bigger alternator.
    I have the 2012 PW but i guess the original owner did not op for the larger alternator.
    any recommendations on setup?
  2. hbleconey
    37
    24
    Apr 30, 2016
    Ram Year:
    Engine:
    After talking to the dealership, it doesnt seem a dual alternator was an option for 2012 and they did not seem enthusiastic about attempting to upgrade it
  3. HS-LD
    HS-LD Member
    82
    25
    Jan 4, 2017
    NE Oregon
    Ram Year:
    2017 2500 Tradesman
    Engine:
    6.4L Hemi
    I tried to get the 220 Alt but I added it as an afterthought and it's the only thing I didn't get so I'm stuck with the 180 for now.
    I assume you can just swap them out if you want to...
    And just a thought, your alternator is 5 years old, maybe it's not up to 100%? Or maybe your battery is going? You might not need to upgrade, just replace back to 100%... (wishful thinking. :) )
  4. hbleconey
    37
    24
    Apr 30, 2016
    Ram Year:
    Engine:
    so i could upgrade at least to the 220 at the dealership? the battery is only a year old so i think its good.
  5. MJockey
    MJockey Member
    94
    37
    Oct 17, 2017
    Ram Year:
    Engine:
    Hemi 6.4L
    I have seen videos of people revving their engines in older power wagons while winching. I guess this is why. I did order mine with a 220 amp alternator just to be safe.
  6. hbleconey
    37
    24
    Apr 30, 2016
    Ram Year:
    Engine:
    dealership said you cant just swap in a larger alternator so you need to find an aftermarket kit of some sort
  7. HS-LD
    HS-LD Member
    82
    25
    Jan 4, 2017
    NE Oregon
    Ram Year:
    2017 2500 Tradesman
    Engine:
    6.4L Hemi
    Not sure I believe them. I would go to Autozone and take a look at both and see if they are the same size. Bet the 220 is the same size with just more wire windings inside or some such thing. I'd be really surprised if the 220 made that much of a difference. But thats just a guess, I could be wrong. :)
  8. Docpaulo
    Docpaulo Senior Member
    304
    72
    Dec 3, 2017
    Ram Year:
    Engine:
    I have factory dual alts... i would look into that... you'll need a lot more juice for those winches than 40amps extra after factoring in loss of efficiency
    Chrisy likes this.
  9. Docpaulo
    304
    72
    Dec 3, 2017
    Ram Year:
    Engine:
  10. Deki
    Deki Senior Member
    163
    56
    Sep 8, 2017
    Phx
    Ram Year:
    Engine:
Share This Page
