Eco Diesel Engine codes
biggdadd58
Diesel
Has anyone out there experienced their eco diesel throwing a code causing it to go into limp mode showing "throttle position sensor" need attention? We have experienced this past week, being close to 0 degrees, a check engine light followed by a "lightning bolt" symbol with the TPS wording flashing on the dash. Dealership is stating that this can be normal when temps are below 32 degrees. That moisture in some lines will freeze and cause the turbo to be underboost. The fix they say is that a cover, along with a block heater may keep this from happening..."may" being the important word.
What and where is the CAC system located on the engine? They are saying that icing in the intake system is causing this to throw a code. Funny part is that they have a part # for a cover but nothing available at this time.
nekosplace
2014 ram
I feel you pain what the dealer told you is bs mine started doing the same thing at 11000 miles and now at 27000 miles it wont last 3-4 days without having to be taken into the shop for a reset it is the boost pressure sensor on the turbo receiving a low pressure signal and after a month and a half where I only had my truck for 7 days they still haven't fixed it
Tach_tech
5.7L HEMI
What code is being set?
huntergreen
Have they replaced the sensor.
RamCares
n/a
n/a
Hi nekosplace,
We are sorry to hear that the dealer is having a hard time diagnosing this concern. Is your vehicle currently at the dealer? Please send us a PM so that we can provide additional assistance.
Darlene
Ram Social Care Specialist
nekosplace
2014 ram
they have replaced the sensor the injectors and throttle body parts and since the last time I was on it went into limp mode again I got to use it for a whole week this time lol
nekosplace
2014 ram
Hi nekosplace,
Darlene
nekosplace
2014 ram
They have given up on trying to figure out the problem personally I think the turbo is shot its not giving the right pressure when I haul anything they are just resetting the sensor at this point and then I drive it till it fails again I love ram brand but this eco diesel is a **** I use ram additive and they are blaming it on Pennsylvania fuel. I am taking it back to the shop tomorrow if you want to get more info call blaise alexander ram jeep crysler in State College pa
nekosplace
2014 ram
electronic throttle control failure when they diagnose it it is the boost sensoe
