9thousandfeet
- Nov 21, 2017
- 16
- 5
- Location
- Rocky Mountains
- 2018
- 6.4 Hemi
Seems like "towing and hauling" might be the right forum for this question, but I'm not sure....
OK, so if I connect a camper trailer (or a slide-in camper for that matter) to the truck ( 2018 3500 Tradesman 6.4) via the 7-pin plug in the truck's trailer wiring harness - then I'll get the camper running lights and all the rest, along with a hot and neutral through which the truck alternator can provide charging to the camper battery bank while driving down the road.
So far so good.
Now, I was told by a guy at an RV place that some of the new trucks have a built-in provision which will prevent the truck battery from being drained by demand from the camper/trailer when the rig is parked (for the night, say) —without the need to physically disconnect anything and without having to install any automatic disconnect - like an ignition-actuated solenoid or something.
Anyone know if the 2018 3500's are set up this way through in the trailer wiring harness?
Or will I have to either install something to automatically protect the truck battery from discharge, or manually unplug the camper from the truck to prevent the camper from pulling current from the truck starting battery?
I just spent more than an hour on the phone trying to track down solid information on this, first with an RV place, then the camper manufacturer, and then with the Ram dealership.
At this point all I know for sure is that the camper system doesn't provide automatic protection for the truck battery, so either the new truck already will, or I'll have to set it up somehow to make it so it does.
So far so good.
