Engine light - Code P0420
cuevrojamez
I have read that I can use a scanner or oscilloscope to check to see if the O2 sensor is bad. Is this something an auto repair shop can do, or could my local auto pets store (O'Reilly/AutoZone) could assist with?
MADDOG
Out Exploring Arizona
Most auto parts stores can read codes and give you a short printout.
Kenworth
Repair shop can easily scan and fix. OBD II code readers are fairly cheap to buy and would diagnose many P codes.
An O2 sensor is not difficult to switch out depending on its location and wether its siezed. If its siezed a little heat with a torch can free it up usually.
C
cuevrojamez
Scanner is reading 2 P0420 codes, I assume 1 for the sensor before and 1 sensor after the cat converter. Is there a way to determine which sensor is bad?
Bullitt5339
St Pauls, NC
The P0420 code is typically only for the sensor after the catalytic converter. It is not an "O2 sensor bad" code, it is a catalyst efficiency code which is normally the O2 sensor downstream from the catalytic converter, but it can also be caused by a bad catalytic converter, vacuum leaks, etc.
You can test them with an O-scope. The voltage range should be between .2-.7 volts and if the cat is in good condition, it should stay pretty close to .5 volts after the engine has warmed up fully. You can try to use a voltmeter, but O2 sensors can switch voltage very rapidly and most voltmeters can't read the changes that fast, so it will average them out.
therapywolf
