Entire row of fuses in interior panel no longer receives 12V
Peter Tiemann
Santa Cruz, California
5.9l V8 gasoline
So, 2 weeks ago, bought a 2002 RAM 2500 from Caltrans (California Dept of Transportation).
It has 2 work lights and the rotating yellow light etc above the cabin. Caltrans disables them prior to sale.
I could use the work lights and tried to see if they just removed a fuse or cut a wire. I found a yellow wire that appears to be recently cut. I could not find the other end of the cut wire. So i gave up on that.
There are 2 simple switches by Caltrans on the dashboard that say "work lights" and "rotating lights"
I confirmed continuity from the work lights switch to the light bulb.
I then ran a wire from one of the interior fuse panel's fuses directly to that switch. I think it was the "trailer fuse". I removed the fuse, put the wire in, other end of wire to the switch, briefly touched the wrong post on the switch, it sparked a bit, then the lights worked (once it was connected to the right post)
I removed the wire then. Was going to do a permanent solution tomorrow.
Put the trailer fuse back in. (Even though I don't have a trailer.)
Was about to leave the job site.
Started truck, it started right up, I turn the steering wheel, I notice the power steering isn't working, then I notice the engine shutting down. It's been dead since then.
The cigar lighter outlet still works. So, I could charge my dead phone and call AAA for a tow truck
The interior fuse panel has 2 rows of fuses. Upper row has all the small fuses.
Lower row has the slightly bigger fuses.
I measured every fuse for continuity.. and all are fine. I noticed that the upper row with the small fuses.. none of the sockets have 12V any more. (They should, right???)
I also looked at the fuses and relays in the engine compartment. Swapped relays a bit, no success.
What would cause the upper row of fuses to go dead?
Thanks..
Big Doge fan here.. I got 4 of them.
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
Check the big fuse off the battery in the under hood fuse box where the power from battery connects.
I will look in my book tonight to see where the power to the dash fuse box comes from.
P
Peter Tiemann
5.9l V8 gasoline
I got it to work
I think the contact of the 50A fuse labeled "ignition" had a bad contact? Dirt?? I didn't have to replace it .
I pretty much disassembled that panel under the hood..
All is working now
