Error code and what I should do.
Dooner
Central Texas
2015 Ram 2500 4x4
P2271 O2 SENSOR 1/2 OUT OF RANGE LOW
That is the error code that I am getting on my 2010 RAM 3500 with 13500 miles on it. Should I just not mess with it and take it back to the dealer which is a hour drive and let them handle it? Or is it a matter of removing and cleaning? I don't want to drive for an hour to find out I could have just used some maf cleaner on it.
Please advise. Thank you.
Dooner
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
13500 miles, under warranty, make the stealership deal with it. just my .02 cents
Mopar1973Man
New Meadows, Idaho
1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
I agree but I would consider getting Pyrometer and Boost gauges soon. Then what you do is get you pyrometer over 1000*F for several miles and it will keep all the emmission stuff clean. The problem with 6.7L they are not design for a daily driver, stop and go traffic, grocery getter, etc. Everyone that owns a 6.7L that tows for a living never has a problem because the engine is being worked and temps are high enough to keep everything clean.
Dooner
Dooner
Central Texas
2015 Ram 2500 4x4
Thanks for the advice.
Mopar1973Man, when you say to get the pyrometer over 1000*F for several miles, do I have to tow something to do this? I do tow a 40' fifth wheel rv trailer a couple times a month, but with work schedules and kids school schedules, we haven't been going on a regular basis like we did during the summer.
Dooner
Mopar1973Man
New Meadows, Idaho
Trailer towing is a excellent way to get the EGt's up. But pyrometer is a excellent way to see if you EGT's are just too cold.
The older Dodge didn't have any need for hot EGT's because there is technically no smog equipment. So now with the O2 sensors, DPF, and EGR valve you got to keep the temps up to control soot deposits.
OPERATION
The oxidation catalyst raises the exhaust gas temperatures to regenerate the DPF, which is passive regeneration. If the passive regeneration cannot keep up with the build up of soot in the DPF, the ECM will actively regenerate the DPF to burn off the soot. Residue remains inside the DPF in the form of non burnable ash. Ash comes from the oils and other materials that are trapped in the oils and are present in the soot. The catalyst contains a large number of parallel channels, which run in the axial direction and are separated by thin porous walls. The channels are alternatively open at one end, but plugged at the other. The exhaust gases flow through the walls and escape through the pores in the wall material. Particulates, however, are too large to escape and are trapped in the monolith walls. The ECM starts the regeneration of the DPF if the soot load exceeds a performance map value. The ECM determines the load condition of the DPF based upon the exhaust gas pressure upstream and downstream of the DPC/DPF. A pressure differential sensor provides the pressure input to the ECM. During the regeneration process, the ECM raises the temperature in the DOC/DPF to burn off the soot accumulated. Under normal operation, the engine does not produce enough heat to oxidize the soot inside the DOC/DPF. This process requires temperatures above 550°C (1,022°F). After regeneration, the ECM reads the actual pressure difference at the DOC/DPF and compares it with a reference value. From this comparison, the ECM determines the ash quantity inside the DOC/DPF.
ramhunter9
P-Star Jeep Wrangler
I also agree , towing is a great way to get those EGT's up there . I have to tow or find a large hill ... anything under load to get over 1k in EGT
If not the injectors will not burn the carbon .. I also know as I just upgraded to larger injectors and the stocks looked like they never seen 1k in EGT
Dooner
Dooner
Central Texas
2015 Ram 2500 4x4
It sounds like the best thing to do is hurry up and get the money to delete that DPF. Seems like it will just be trouble.
I thank you guys for the info and advice.
Dooner
greenojos1981
Dooner, did you take your truck to the dealer? What was wrong with it? I have a 2010 w/ 12000 miles on it & I got the same code present. Just came on last night, so I haven't had time to go & get it looked at yet.
Mopar1973Man
New Meadows, Idaho
What's your driving habits like?
greenojos1981
Varies, usually some city driving, but I get on the freeway everyday and do like 70 or so to burn off the exhaust. I have other 6.7's with similiar driving & one that only has city driving (no highway) and that code never came on before.
Dooner
Dooner
Central Texas
2015 Ram 2500 4x4
I haven't taken it in yet. It seems to be running fine. As soon as I do, I will post what they do.
Dooner
6.7CumminsDrvr
The Dude abides………
Georgia
I'll guess a fouled up sensor. My 2010 is deleted and I have almost 37k miles on her now, all trouble free. If you are going to keep the truck I'd delete it and not look back. My truck runs so much better and I picked up an honest 3 mpg hand calculated.
Dooner
Dooner
Central Texas
2015 Ram 2500 4x4
I finally took my truck in to get checked out. Took long enough.
They show code P2271 OS Sensor 1/2 Rich. Diagnosed with a faulty sensor. Replaced the sensor.
It sure made a big difference in how it runs and how the transmission shifts. Seems to shift more smooth and easier. All is well now.
Dooner
ramhunter9
Good to hear it is all fixed man .
1Popeye
