exhaust work
Discussion in 'Engine & Performance' started by 12vcummins59, Jan 1, 2017.
Sponsored By: Moe's Performance
  1. 12vcummins59
    12vcummins59 Member
    25
    71
    Aug 27, 2016
    Ram Year:
    1996
    Engine:
    Cummins 5.9
    My 96 ram 2500 with a 12 valve currently has a 7 inch side dump straight pipr exhaust which is a bit too loud for me and any neighbors within a half mile. I want to change it to just a 4 inch straight pipe with maybe a 5 inch tip. Where's the best place to get the material for this and is it better to clamp the pipes together or weld them? Thanks
  2. dapepper9
    dapepper9 Senior Member
    22
    4,831
    1,865
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    Easiest would be a turbo-back 4" kit. All over summit, ebay, Amazon, or any diesel performance site. Weld is better than clamp in nearly every case, less leakage. Or you can also order any build it yourself kit of bends and such and build your own
  3. 12vcummins59
    12vcummins59 Member
    25
    71
    Aug 27, 2016
    Ram Year:
    1996
    Engine:
    Cummins 5.9
    What would be the cheapest way to go? I. Not worried about it looking ugly as long as it works, doesn't leak, and doesn't fall apart. I have custom built and exhaust for my race car out of a few other exhausts I had laying around, I'm just looking for something easy and cheap
  4. dapepper9
    22
    4,831
    1,865
    Feb 7, 2013
    Ram Year:
    2001
    Engine:
    5.9L V8
    Well if you want a full tailpipe, ebay kit like this.
    On paper, you could likely find all the piping for less. However, this isn't a lot and you'd be done in at the most a half days work. No measuring cutting or welding, she'll bolt right in. Done. But, then again if you have the tools and know-how you could build a system for not very much depending on where you get the pipe.
  5. e_hartzell17
    e_hartzell17 Senior Member
    20
    110
    10
    Jul 26, 2016
    Ram Year:
    2001
    Engine:
    5.2 318
    Agreed it's gonna be cheap and a lot easier to buy the full exhaust off of eBay and on the up side it's gonna look pretty too
  6. e_hartzell17
    20
    110
    10
    Jul 26, 2016
    Ram Year:
    2001
    Engine:
    5.2 318
  7. 12vcummins59
    12vcummins59 Member
    25
    71
    Aug 27, 2016
    Ram Year:
    1996
    Engine:
    Cummins 5.9
    Thanks for the suggestions guys I will look into buying one
Share This Page
