VernDiesel
A re post
Looks like we are going to get the 2018 F150 instead of the ram. Both are V8. Ford has 1800 Lbs payload, ram is 1500 lbs. both pull right around 9200 Lbs. The trailer we want has dry weight of 6500 and TW of 701. Will this work out ok? I have been asking a lot of questions and researching a lot as well. I just want to get it right.
Boggs, Typically people add almost 1000 pounds from dry weight to camp ready. That puts your TT at almost 7500. With WD & WDH adjusted according to scales you should get to a TW of about 12 percent or 900 pounds. Remember all 1/2 ton Mfgs recommend a WDH for towing 5,000 pounds or greater. Best non special order regular axle set ups that you typically find at dealerships have Fords towing payload or GVWR at 7,000 and Ram's at 6,950 usually leaving 5 to 600 pounds for people & stuff. Specked with the appropriate motor & gear any Mfgs 1/2 ton will have enough power to tow a 7,500 pound TT and with proper weight distribution will handle it safely & with stability.
It's always more about suspension capability than power with respects to 1/2 tons. For comparison below is a small chart ranked by combined axle weight rating.
Mfg-GVWR-steer-drive-combind
Toyota 7,200-4,000-4,150-8,150
GM. 7,200-3,950-3,950-7,900
Ram. 6,950-3,900-3,900-7,800
Ford. 7,000-3,600-3,800-7,400
Nissan 7,100-3,500-3,800-7,300
Naturally you still have other factors such as fuel economy and braking power which is reflected in the CVWR. Toyota looks best here with 8,150 but has the worst fuel economy and some owners complain about their brakes when trailering mountain grades. Point is there is lots to consider when picking a truck especially if it's not a dedicated TV but a multipurpose vehicle.
Main thing for safety and stability when towing with your family is to scale. The DW & kids don't need to come just a camp ready ish TT. To set up your load you will want your unloaded TV front axle weight, best is to get it from the scale as job 1 will be to replace that weight when loaded with wet TT.
You will need your axle ratings from your door sticker which may differ from the chart. As job 2 will be making sure your WDH transfers enough weight off your drive axle back to the steer & TT axles that you don't exceed your drive axle weight rating.
Your scale slips will also show your CVW so you can make sure your not exceeding CVWR. Your slip will also show your TV weight so you can verify that your not over GVWR or towing payload. Last you can calculate your actual or seen TW to see that your not exceeding your receiver weight rating and to verify that you are in the 10 to 15 percent tongue weight range for maximum stability. Happy camping.
PS I picked Ram 1500 Economy diesel mostly because of fuel / towing economy which it averages 30 unloaded & 14.0 with a double axle box TT at 65 mph. Diesel longevity, which it has 370,000 miles now. And braking or speed control for when the TT is pushing you down a mountain grade. With tune supplied turbo brake and factory supplied trailer brake controller it puts me in a position to never have to touch the truck foot brake to control speed towing down a mountain grade. This provides a lot of safety and confidence. In fact my original brakes went 293,000. The 100k warranty didn't hurt either.
