Feels like tire is loose
Discussion in 'Tech Info' started by swungspeedz, Jun 13, 2015.
  1. swungspeedz
    swungspeedz Junior Member
    19
    19
    Jun 7, 2015
    Ram Year:
    2001
    Engine:
    5.2
    Feels like tire is loose buts it's tighten up good. Feels like a wobble af slow speeds.
    Sent from my SPH-L710 using Tapatalk
  2. MagSport
    MagSport Senior Member
    22
    1,256
    499
    Mar 10, 2014
    South Carolina
    Ram Year:
    1999
    Engine:
    5.9
    If the tire is tight and the hub is tight your tires may be out of balance. What speed does it do it in?
  3. swungspeedz
    19
    19
    Jun 7, 2015
    Ram Year:
    2001
    Engine:
    5.2
    Just while going 10 mph or below it does it
  4. Ram digger
    Ram digger Member
    29
    53
    15
    Aug 24, 2014
    Medicine Hat AB
    Ram Year:
    1997
    Engine:
    5.2 magnum
    Wheel bearing on its way out possibly , mine blew apart yesterday while I was driving. If you haven't already jacked it up in the front, try that and see if there any play or slight movement on ither front tire. That's all I can think of.
    tommyboi87 likes this.
  5. tommyboi87
    tommyboi87 Senior Member
    861
    205
    May 28, 2014
    houma louisiana
    Ram Year:
    1999
    Engine:
    5.2 Magnum
    ^^^ that. Also check your rotors. Not really common at low speed, but still could be warped. Is there any camber that you can see?the upper control arm bushings could be shot. Got an egg in any of your tires? Rotate the fronts to the back and see if your problem goes away.
    Sent from my SAMSUNG-SM-G925A using Tapatalk
  6. swungspeedz
    19
    19
    Jun 7, 2015
    Ram Year:
    2001
    Engine:
    5.2
    Know this is a old thread but eventually it was my axle .
    Sent from my SM-G900P using Tapatalk
Share This Page
