First the windows, then cruise now nothing!!
Discussion in 'Audio & Electronics' started by Nwa-ram, Jan 30, 2015.
  1. Nwa-ram
    Nwa-ram Junior Member
    14
    Oct 9, 2012
    Ram Year:
    1989
    Engine:
    5.9l Cummins
    I am about at my wits end... the basics 1993 D250 12v cummins 5 speed.
    Symptoms...
    Started with the Hvac and windows not working. I could bridge across and get them to work fine. Never found any breaks or shorts. Then the cruise control started acting funny, would cut in and out going down road some days would not work at all then stopped working all together. Finally a buddy borrowed it to pull a 5th wheel trailer as he pulled into its parking spot it died.
    I have checked the fusible links all good except the one that feeds the solid red i dont believe its the link as there is no power before or after the link....
    When you turn ignition NOTHING happens no dash lights, buzzing, warning light's etc when you turn to start zilch happens as well.
    Been doing a lot of reading and I am thinking its either the ignitin switch itself, a bad relay or possibly a bad ecu?? How can i go through a process of elimination before i just start replacing parts! Thank you in advance!!!
  2. crazzywolfie
    crazzywolfie Senior Member
    14,101
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    the orange fusible link that goes to the red wire powers most of the stuff in the cab. the orange fusible link that goes to the pink wires power your heater and power window
  3. Nwa-ram
    14
    Oct 9, 2012
    Ram Year:
    1989
    Engine:
    5.9l Cummins
    So it was the fusible links... partially. Replaced all of it with a fuse block. However in the process noticed a missing relay... anyone know what relay this is???[​IMG]
    Its all the way back towards the firewall
  4. crazzywolfie
    14,101
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    you may want to keep lots of fuses on you because i don't think a fuse block will really work very well in place of the fusable links
    that is your obd1 computer port.
  5. Nwa-ram
    14
    Oct 9, 2012
    Ram Year:
    1989
    Engine:
    5.9l Cummins
    Oh. Well learned something new!
    Why wouldnt fuses work in place of a fusible link? Its all the same concept
  6. crazzywolfie
    14,101
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    fuses usually blow instantly when overloaded where fusible links don't.
  7. Sniper X
    Sniper X Senior Member
    50
    113
    10
    Dec 7, 2016
    Ram Year:
    1991
    Engine:
    318
    I changed all my fuseable links on my 77 ramcharger a d my 1991 no power wagon and have never had a problem.
  8. crazzywolfie
    14,101
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    maybe you have got lucky so far. i personally wouldn't run them. on my 81 i got the newer style fusible links replacing the old ones. they work just like fuses and can easily be swapped out or bypassed but i also installed a power distribution center.
    [​IMG]
  9. Sniper X
    50
    113
    10
    Dec 7, 2016
    Ram Year:
    1991
    Engine:
    318
    If you mean me getting lucky swapping them out to fuses, they have been in my Ramcharger for over 20 years, working perfectly, and in my truck for five years.
Share This Page
