Floor mats
Discussion in 'Interior' started by bhonshell37, Dec 21, 2016.
  1. bhonshell37
    bhonshell37 Senior Member
    44
    629
    134
    Dec 15, 2016
    Ram Year:
    Engine:
    I have a 98 Ram Sport. I need to semi permanently a fix my front rubber floor mats to my carpet. I have tried carpet glue, velcro with no luck. I was thinking perhaps a button remedy. I need some ideas in or out of the box.
    Sent from my SM-T550 using Tapatalk
  2. dudeman2009
    dudeman2009 Senior Member
    22
    1,453
    166
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    Just put grommets into four corners on the mat and tie it down. You can tie two corners to the seat mounts, and the other two can tie in under the dash. Sure it can lift up, but it wont move around on the floor much.
  3. avantiguy
    avantiguy Senior Member
    75
    320
    110
    Dec 9, 2015
    Bay City, Mi
    Ram Year:
    Engine:
    hemi
    Sounds like you want them well attached so just go to the hardware and buy some big headed pop rivets. Aluminum will be easier to use. Be careful where you drill and put them in. They are easy to drill out when you need to remove them.
  4. bhonshell37
    44
    629
    134
    Dec 15, 2016
    Ram Year:
    Engine:
    Thank you gentlemen for the replies
  5. dapepper9
    dapepper9 Senior Member
    22
    4,830
    1,864
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    Pop rivets with a rubber gasket under the mat wouldn't be a bad idea
  6. bhonshell37
    44
    629
    134
    Dec 15, 2016
    Ram Year:
    Engine:
    The floor mats need to semi permanently attached. I am not willing to drill through the floor pan. When needed, I want to be able to remove and vacuum under them. Please keep the ideas flowing
  7. dudeman2009
    22
    1,453
    166
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    Engine:
    Magnum 360
    If you want ease of vacuuming, you could always go buy those woven straps with the quick release buckles like those backpacks that clip in the front. Attach them to the seat frame and floor map with a real short lead so the mat cant move very much.
  8. bhonshell37
    44
    629
    134
    Dec 15, 2016
    Ram Year:
    Engine:
    I like the backpack strap idea. Perhaps a fabric store will have the straps.
Share This Page
