Kvothecomplex
- May 10, 2017
- 4
- 0
- 1999
- 5.2 318
Is there anyway to test whether the knocking sound im hearing is the flywheel or a rod bearing starting to go? The knock is not loud and is heard best from the frontpassenger side fender well in less you actually climb underneath. Once down their its hard to confirm whether the sound is coming from around the oil pan ir from behind the plate that houses the flywheel. Was hoping someone knew an easy way to confirm which it is?
