foam gun and no touch car wash.
HEMI_Finn
U.S. ARMY Veteran
N.E. Ohio
The 40 is for rinsing, the 65 is for soap from say, a reservoir on your pressure washer or something else. The cannon should hook up to the wand just like putting a tip on the wand.
Sent from my SM-G900V using Tapatalk
Curlyp
OH
Ah okay. I understand now. Thank you. I'm about to test out the rinse! The foam cannon will be here this week[emoji38]
HEMI_Finn
U.S. ARMY Veteran
N.E. Ohio
Have fun and good luck!
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
pretty much what he said lol
that black nozzle is nothing close to a foam cannon, the foam cannon will plug in the same way as those tips and will have a bottle attached to it that holds your soapy mixture
Curlyp
OH
Just got my cannon today!!!
Curlyp
OH
Thank you everyone for your recommendations on the foam cannon and pressure washer tips. The 40° nozzle worked well! I need to play around with how much foam soap to use in the bottle, I might need more as it started to run fairly quick.
mills3
Brookville, PA
I bought one on Ebay too that was rather inexpensive. It works amazing! I use mine with my Sunjoe pressure washer everytime I wash my truck. I not only use it for my own personal use, I also use it when doing other people's vehicles.
Farmer Fran
Earth
2020 Limited Loaded - Sold
I have never tried that, do I assume correctly that you still have to towel dry it to get a good sheen?
I did not read the rest of the replies but I use polish angel and all it takes is my leaf blower to dry the truck. No water spots at all
mills3
Brookville, PA
nice: very simalar to mine, you will love it.
Play with the amounts of soap you use.
I have the same cannon. I use a Sunjoe pressure washer all of the time with my cannon. Like you said, you have to play with the amounts of soap you use. And it depends on what soap you have. I use Adam's Car Shampoo. I typically use one ounce of soap, just so it coats the bottom. I add my warm water and fill it up about halfway. I then mix it up (but don't shake it) and then attach it. I've had awesome results doing this.
https://www.instagram.com/p/BSzC6c1hVr7ahFCsqiV1q1aQ_ChwQOlNoMbQLs0/?taken-by=ofcmills3
