CostaRam
lock button was notworking and there was no click either.
take out the key, pry the FOB open and pull out the cirquit board.
In the rubber shell are 4 tiny cups sticked on with some caulk and depressing them they make contact and the click feeling.
Pull them out, eliminate the tiny amount of yellow sticky caulk an clean them.
Then i used those sticky chewing gum type rubber squares used to stick things on a wall, but THIS ones (or double side sticky tape) should work as well.
Cut a small circle out of the tape and stick the small cups back in place on the rubber shell.
That worked perfectly for me!
Chris
Chris
