Fog lights on an ST?
icywhite
second owner on mine got it when it was a year old as a repo. mine is a 5 speed and it has cruise the rubber mat instead of carpet which i luv. with cloth seats and yes there is a connection for the overhead i added an overhead console some years back
Crod05
2002 Dodge Ram 1500 ST
4.7L magnum V8
How where you able to install everything if your truck wasnt pre wired for fog lights? Thanks
Crod05
4.7L magnum V8
Since you bought the factory kit, just follow the instructions and install the complete kit. When I installed a kit on 2002 ST none of the factory fog light wiring was there so I had to install everything.
How where you able to install everything if your truck didnt come pre wired for fog lights? Thanks
reindeerman
Knoxville, TN
2011 & 2002
The kit came with everything needed, including wiring, relay and switch. You can still find them on EBay search 2002-2008 dodge ram fog light kit
Joepete859
Indiana
I have a 2006 dodge ram 1500 st 2wd v6. We are wanting to install fog lights. I purchased set of light and bezel after market and bought new switch for interior so it looks factory. I am not seeing any plugs up by front bumper so if was to purchase a harness where would it plug into of course to the lights but where on other end. I have been searching for days for an answer. Screenshot_20171228-155502.png
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
20160307_144510.jpg That should be outside air temp sensor. Its mounted in the driverside front. Ive moved mine long ago and not sure where it was originally.
OC455
Central NY
Resurrection happening here....
05 Ram 1500 ST model. Wiring harness plug present on the driver's side bumper/frame bracket for fog lights. Bought the jumper wiring harness for the fog lights, aftermarket LED fogs, fog light bezel/trim, OEM used factory headlight/fog light switch. Installed the relay for the fog lights(#62) checked the fog light fuse (good). Plugged everything in, installed the fog lights, and turned everything on and nothing happened. What am I missing?
OC455
Central NY
I checked the plug that was there and used a voltmeter, no voltage coming in with the headlight switch on with the fog light switch pulled out.
OC455
Central NY
There was power at the fuse for the fog light and power at the fog light relay....but none to the wire harness at the plug behind the bumper? Maybe i got a bad switch?
am3334
