Frame swap
Discussion in 'Exterior' started by Micchi, May 30, 2017.
Sponsored By: BAK Factory Outlet
  1. crazykid1994
    crazykid1994 Senior Member
    944
    180
    Sep 21, 2013
    Ram Year:
    Engine:
    Not for certain that it is that. Just something else to keep in mind. I got lucky when I did the clutch in my car because it was a common fail point on that make of vehicle
  2. Micchi
    Micchi Senior Member
    252
    55
    Feb 25, 2012
    West Lawn, PA
    Ram Year:
    1999
    Engine:
    5.2L
    Not sure what else would be leaking but now I get to drop the trans to find out.
    Sent from my SM-G920P using Tapatalk
  3. Micchi
    252
    55
    Feb 25, 2012
    West Lawn, PA
    Ram Year:
    1999
    Engine:
    5.2L
    Well found the problem, now I just hope that it didn't damage anything else and that it's all in the pan. New lifters showed up from summit so I am going to replace all of them just in case any others are about to go[​IMG][​IMG][​IMG]
  4. crazykid1994
    944
    180
    Sep 21, 2013
    Ram Year:
    Engine:
    Well then. That’ll do it...
  5. Gr8bawana
    Gr8bawana Senior Member
    269
    66
    Dec 7, 2015
    Ram Year:
    1997
    Engine:
    5.9
    Oh crap!
    Micchi likes this.
  6. Micchi
    252
    55
    Feb 25, 2012
    West Lawn, PA
    Ram Year:
    1999
    Engine:
    5.2L
    Yeah
  7. crazzywolfie
    crazzywolfie Senior Member
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    have you checked the cam to see if it is damaged? i wouldn't be surprised if something like that could have wiped out a cam lobe
  8. Micchi
    252
    55
    Feb 25, 2012
    West Lawn, PA
    Ram Year:
    1999
    Engine:
    5.2L
    I'm going to rotate it again but I couldn't see anything when I looked
    Stefan N likes this.
  9. Micchi
    252
    55
    Feb 25, 2012
    West Lawn, PA
    Ram Year:
    1999
    Engine:
    5.2L
    Ok well crap, didn't look at the whole thing when I first took a look. But somehow a lobe for cylinder 1 and 2 are done for. Not sure how I managed to do this but looks like I'll be getting that cam I was thinking about[​IMG]
  10. crazzywolfie
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    well considering how damaged the lifter wheel looked that is not surprising. the wear on the wheel that shows it has been chewing on metal. i personally don't know if i would consider just tossing a brand new cam and lifters in that engine without completely tearing it apart and making sure the engine is clean. if you wiped out 2 or more lobes like that then there is likely lots of tiny metal particles floating around the engine/oil that might have been pumped through the engine while you were driving it.
Share This Page
