Front Bilsteins are finally on
Discussion in 'General Discussions' started by 02blkram47, Feb 12, 2012.
  1. 02blkram47
    02blkram47 Senior Member
    1,087
    71
    Oct 19, 2011
    Lebanon, NH
    Ram Year:
    2011 Longhorn Crew Cab
    Engine:
    Well after 6 hours and two days I finally have my front shocks replaced. What I expected to be an hour tops turned into a nightmare install. Decided to do my drivers side first and right from the start i had issues. Top nut was so stuck I ended up using my saw to cut the Bolt off. Then I go to work on the bottom bolt and my 80 gallon air compressor decided to spring a leak so it won't build enough pressure to loosen the bolt. So after two trips to home depot I end up with a very large socket and a cut length of metal tube for leverage so I can step on it and loosen the bolt. Finally in the dark I finished my first shock. Wake up today and start right in. Only this morning its 14 degrees outside, I started with the bottom bolt and that came right off. Start on the top and it too is so stuck I'm screwed. Finally after stripping the top of the shock so badly nothing can hold it I started to use the nut below the mount to counter act the nut above the mount and it came off. So long story but happy to be riding on four new Bilstein shocks.
  2. MADDOG
    MADDOG Super Moderator Staff Member
    7,434
    1,978
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
    Cummins 6.7L Turbo Diesel
    Nice mod! So where's the before and after pics???
  3. Bluesmoke91
    Bluesmoke91 2nd GEN Site Mod Staff Member
    3,160
    233
    Nov 26, 2010
    Baldwin Park, California
    Ram Year:
    Engine:
    Hows the ride quality now bud
    Sent from my DROIDX using Tapatalk
  4. 02blkram47
    1,087
    71
    Oct 19, 2011
    Lebanon, NH
    Ram Year:
    Engine:
    The ride is much better. No knocking anymore. I had sensatrac shocks on there before, the bilsteins are much nicer. I'm happy with the mod.
  5. bigbadram1500
    bigbadram1500 Administrator Staff Member
    38
    15,293
    583
    Jul 7, 2010
    Springfield, IL
    Ram Year:
    2008
    Engine:
    Sucks about the trouble, awesome they are on and good now :)
  6. MADDOG
    7,434
    1,978
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
    about those pics....tap...tap...tap...tap...tap...
  7. LB3711
    LB3711 Super Moderator Staff Member
    43
    18,170
    1,519
    Jan 23, 2011
    Trumbull, CT
    Ram Year:
    Engine:
    6.4L Hemi
    I have used nut breakers before to get at seized nuts.
  8. 02blkram47
    1,087
    71
    Oct 19, 2011
    Lebanon, NH
    Ram Year:
    Engine:
    Never heard of nut busters? Sorry I don't really have any before and after photos.
  9. BlackedOutHemi
    BlackedOutHemi Senior Member
    24
    5,462
    186
    Feb 27, 2011
    DFW, Texas
    Ram Year:
    2012 & 2012
    Engine:
    5.7L HEMI & 6.7L Cummins
    Nice buddy! Sucks that it was a pain though.
Share This Page
