Front door speaker fitment
Discussion in 'Audio & Electronics' started by PCA4208, Oct 30, 2016.
  1. PCA4208
    PCA4208 Senior Member
    2,531
    408
    Nov 27, 2012
    Albuquerque, New Mexico
    Ram Year:
    2006
    Engine:
    Which front door speakers will fit the best with no modifications to the door? Just got a new (to me) 2006 ram 1500 Quad cab. I bought some Rockford Fosgate 6x9's but the basket is huge and won't fit without some major cutting. I would rather not cut my door up, but I also want quality speakers in the doors. Anybody have any suggestions on what speakers to get that would fit, or has anyone cut their door to fit larger speakers have any tips?
  2. justin13703
    justin13703 Senior Member
    28
    978
    293
    Oct 15, 2014
    MD
    Ram Year:
    2008
    Engine:
    I have infinity kappa 6x9s in my front doors and I had the same problem as you. The baskets are huge and won't let the speaker fully seat into the cutout. Instead of cutting the door up, I basically just tightened the screws in the speaker until they were tight, which left me with about a 1/4" gap between the speaker and the door. I then just used some strip caulk to fill the gap. You can get it at lowes. It's a rope of putty-type stuff that you can use to fill in gaps like that. I've had them installed like this for years with no issues.
  3. Core-Lokt
    Core-Lokt Senior Member
    382
    79
    Jan 13, 2013
    Ram Year:
    2005 Ram 2500 4X4 ST
    Engine:
    5.7L
    Basket..I didn't know it was called that. Good to know.
    I replaced speakers last year. Some Kicker 6X9 model, and the basket was too large to go in the existing opening, also. I used some spacers from Scosche trimmed to ~1/2" margin. The slight extra height meant the new speaker fit great with full support around the rim.
    It's quite easy to comprehend what I did, but I have some pictures in my thread about Android HUs.
  4. bcbouy
    bcbouy Senior Member
    1,084
    398
    Nov 12, 2014
    pitt meadows
    Ram Year:
    2012 ram 2500
    Engine:
    hemi
    that's about how my hertz 6x9's went in.the gap wasn't that large though.only a few mm on the last screw. so far so good.the stock speakers were very shallow.i also didn't want to cut the door and use the hertz covers,so mine looks factory.
    jhosler likes this.
  5. IJW84
    IJW84 Junior Member
    26
    Feb 19, 2016
    Ram Year:
    2008
    Engine:
    6x9 Alpine SPS-619 model will fit perfectly.
  6. Bullitt5339
    Bullitt5339 Senior Member
    920
    507
    Jul 5, 2015
    St Pauls, NC
    Ram Year:
    Engine:
    3.7
    The model number for these spacers if anyone else needs them is Scosche SS69
  7. PCA4208
    2,531
    408
    Nov 27, 2012
    Ram Year:
    2006
    Engine:
    Anyone know of how large of a spacer will fit behind the door panels? I really want to use these speakers and thought of using a spacer. I found a 3/4 inch one and 1 inch. I think that 1 inch will make it fit perfectly but I don't know if they will fit behind the door panel.
  8. Core-Lokt
    382
    79
    Jan 13, 2013
    Ram Year:
    Engine:
    5.7L
    The spacers I got from Crutchfield were 1/2" thick. I am confident 3/4" would've been fine with my speakers. Not sure about 1" or other brand speakers, though.
    The spacers are inexpensive. I would get both sets You could even get something like plastic cutting boards and make some.
  9. PCA4208
    2,531
    408
    Nov 27, 2012
    Ram Year:
    2006
    Engine:
    Figured out that I didn't need spacers after all. Turns out that the best way to fit them in was a hammer to "finesse" the sheet metal a bit. Now I just need to get a new headhunt that'll power these bad boys.
  10. justin13703
    28
    978
    293
    Oct 15, 2014
    MD
    Ram Year:
    2008
    Engine:
    You aren't going to find a head unit that will put out more than about 15 watts rms per channel. If they can handle any power the best thing to do is to amp them.
Share This Page
