Front end sqeeking
Discussion in 'General Discussion' started by jonwalden68, Feb 18, 2014.
  1. jonwalden68
    jonwalden68 Member
    44
    Feb 12, 2014
    Ram Year:
    1999
    Engine:
    5.2
    I noticed the other day finally got warm enough to roll window down and I noticed a sqeeling from the front sounds like driver side it does it whole time while driving it sounds like brakes but hitting the brakes doesn't affect the sound or make noise worse any idea? I don't wanna replace brakes if it's not it just don't know what else
  2. Merc225hp
    Merc225hp Senior Member
    5,141
    3,117
    Jan 13, 2013
    NA
    Ram Year:
    truck
    Engine:
    gas
    It could be the Unit bearing/wheel bearing is on it's way out. Jack the truck up on that side grab the tire and see if it has any side to side or top to bottom movement in it.
  3. jonwalden68
    jonwalden68 Member
    44
    Feb 12, 2014
    Ram Year:
    1999
    Engine:
    5.2
    I know there is some play. Side to side but I was gonna wait till
    I could afford to buy both till I replaced. I was wondering if the brakes could just be rubbing rotor constantly and sqeeking but seems like it would get worse when I hit brakes or stop the noise one
  4. NYCruiser
    NYCruiser Senior Member
    2,565
    789
    Dec 17, 2013
    Yonkers, NY
    Ram Year:
    Engine:
    If it doesn't change with the brake pedal, it isn't the brakes. Sorry.
  5. jonwalden68
    jonwalden68 Member
    44
    Feb 12, 2014
    Ram Year:
    1999
    Engine:
    5.2
    Are the bearing on the 4wd press in or bolt on? Trying to figure if I can do it myself
  6. jonwalden68
    jonwalden68 Member
    44
    Feb 12, 2014
    Ram Year:
    1999
    Engine:
    5.2
    Took off the wheel brakes and rotors good. Hub is bad, needs upper ball joint. Can you replace the u joint on axle shaft? And what is the bearing or seal called were the axle shaft goes into axle
  7. Bigtman07
    Bigtman07 Registered User
    9,306
    207
    Jun 28, 2010
    Eaton, Ohio
    Ram Year:
    1998/2000
    Engine:
    Magnum 5.9/Cummins 5.9
    The Hub and bearing is all in one unit. If you have All Wheel ABS its not a cheap part. The axle u joint is replaceable along with the ball joint.
Share This Page
