Fuel Issues
Discussion in 'General Discussions' started by SilverStreak88, Nov 29, 2016.
  1. SilverStreak88
    SilverStreak88 Senior Member
    3,951
    1,583
    Jul 20, 2015
    Houston, Texas
    Ram Year:
    Engine:
    5.7 Eco Gasser
    Wife was driving the truck the other day and called saying wouldn't start. She said it was starting rough and died, got it to start the second turn over and made it back home. I went out to look and it just turned over and kinda sputtered, but didn't start. Turned the key to "ON" position and the pump isn't priming. Since the relay is internal and the fuses are good for everything else I moved to the pump to check it. While under the truck I hit the remote start and nothing from the pump, I can't find a pinout for the harness, I got 19 Ohms on blue/white and small black wires (guessing sending unit). Any ideas or diagram for the pump, which pins are 12V?
Share This Page
