fuel leak no start
Discussion in 'P Pump' started by 12vcummins59, Nov 8, 2016.
  1. 12vcummins59
    12vcummins59 Member
    25
    71
    Aug 27, 2016
    Ram Year:
    1996
    Engine:
    Cummins 5.9
    Can a fuel leak where the line from the lift pump connects to the top of the fuel filter/ water separator cause the truck to not start? The filter is definitely getting fuel as it is over flowing but I try to bleed the injectors and no fuel. Could air getting onto the system cause this?
  2. BrianandChrissy
    BrianandChrissy Senior Member
    48
    578
    212
    Jul 11, 2016
    Buffalo NY
    Ram Year:
    2016 big horn crew cab
    Engine:
    5.7 hemi, vararam CAI
    You ran the system dry bud
    sent from galaxy S7 edge using tapatalk
  3. 12vcummins59
    12vcummins59 Member
    25
    71
    Aug 27, 2016
    Ram Year:
    1996
    Engine:
    Cummins 5.9
    Should I be able to fix the leak and bleed the injectors and get it running?
  4. BrianandChrissy
    48
    578
    212
    Jul 11, 2016
    Buffalo NY
    Ram Year:
    Engine:
    Cant bleed em. Gotta pressurize the whole system again
  5. vgoodson91
    vgoodson91 Member
    26
    79
    26
    May 5, 2016
    Ram Year:
    Engine:
    Bleeding the lines on a p pump won't do any good. It's only the vp pump on the 24 valves that requires you to bleed the air out. That mechanical lift pump has to have backside pressure to be able to push the fuel up to the injectors. Cracking the lines at the injector actually allows air back into the system on the back side and will keep the fuel from ever reaching the injectors. On the manual lift pump down on the side of the driver side of the motor there is a lever you can pump to re prime the system. It's gonna take a lot of pumps but it works. Or you can just keep cranking till it fires up. Or if you have a manual trans have someone drag you around in 3rd or 4th gear until it starts up.
    Rustycowl69 and BrianandChrissy like this.
  6. 12vcummins59
    12vcummins59 Member
    25
    71
    Aug 27, 2016
    Ram Year:
    1996
    Engine:
    Cummins 5.9
    So fix the leak and prime the hell out of it and she should start?
  7. vgoodson91
    vgoodson91 Member
    26
    79
    26
    May 5, 2016
    Ram Year:
    Engine:
    Yes sir. The priming is the sucky part. That's where a manual tranny makes all the difference. Or hook a battery charger up and just crank on it for 10 seconds or so at a time until it fires. Every time the crank rotates it pumps the pump essentially doing the same thing as you pumping the prime lever
  8. 12vcummins59
    12vcummins59 Member
    25
    71
    Aug 27, 2016
    Ram Year:
    1996
    Engine:
    Cummins 5.9
    Thank you it is a manual so that'll help
    BrianandChrissy likes this.
  9. vgoodson91
    vgoodson91 Member
    26
    79
    26
    May 5, 2016
    Ram Year:
    Engine:
    No problem. Let us know how it goes
  10. BrianandChrissy
    48
    578
    212
    Jul 11, 2016
    Buffalo NY
    Ram Year:
    Engine:
    This is exactly why i love this forum. Great minds coming together to help one another. Now if only the president, congress, the house and the Senate could follow suit... this country could truly be great again!!
Share This Page
