Charger
I fellas, am I correct in thinking that the minimum fuel pressure is 47 psi? I'm having a problem that the truck will start and rev up to 2000 Rpms and drop to 1000 stutter and die. Rented a fuel pressure kit (was a new one) and hooked it up to the Schrader valve on the fuel rail. getting 35 psi and dropping to 23. Fuel pump is running its **** off with a smooth and steady whirr. The pump shuts off at 35 psi. What else controls the pressure?? The PO swears that the pump was changed about a month before I bought it. And this truck sat a while before I bought it.
