Fuel Problem, not the fuel pump
Discussion in 'Tech Info' started by pwebyd90, Feb 7, 2015.
  1. pwebyd90
    pwebyd90 Junior Member
    13
    Feb 7, 2015
    Ram Year:
    2001
    Engine:
    5.9L magnum
    So I'm driving down the road and I lose power.. can rev the motor but its not going any faster, just coasting to a stop.. I thought it was the transmission by the way it was acting. When I get to a stop, the truck dies, so I try to start it back up and it feels like its misfiring on all cylinders, runs for a few seconds, then dies again, but starts up every time.
    Get it towed home and change the IAC valve, detail the throttle body, nothing helps. So I figured it might be the fuel pump even though its getting gas at the rails and I can hear the pump kick on. Do a test and its shakey at about 45-48psi.. but then sometimes while its started and shaking violently, something will catch and it will run perfect, but rev to like 4k, then slowly go back down and die. Well it did this while the pressure tester was hooked up, and while it was running perfectly the psi jumped to a steady 50. Fuel pump! I thought, so I had one overnighted to me.. changed it out today, started her up, and exact same thing is happening.. Anyone have any ideas? Also like to add I'm only getting one code and its gas cap leak... might be important now that I think about it
    2001 Dodge Ram 1500
    5.9L v8
  2. MagSport
    MagSport Senior Member
    22
    1,256
    499
    Mar 10, 2014
    South Carolina
    Ram Year:
    1999
    Engine:
    5.9
    I had this issue shortly after I did my heater core. Cleaned my battery terminals and tightened everything down tight and it fixed it. Don't know if it would be the same for you, but if these trucks have a bad connection at the battery, the Ecms go all crazy
    MoparMagic'00 likes this.
  3. crazy_luck
    crazy_luck Senior Member
    1,108
    730
    Nov 9, 2014
    Minnesota
    Ram Year:
    Engine:
    Some of this sounds like symptoms of a plugged/bad catalytic converter...
  4. pwebyd90
    13
    Feb 7, 2015
    Ram Year:
    2001
    Engine:
    5.9L magnum
    If it were the cat would it throw any codes? And I'll check the battery when I get home, I'm out of town for a couple more days.. Thank you for the replies
  5. pwebyd90
    13
    Feb 7, 2015
    Ram Year:
    2001
    Engine:
    5.9L magnum
    Were you having these exact problems? If it turns out to be just the battery I would be sooo happy :)
  6. MagSport
    22
    1,256
    499
    Mar 10, 2014
    South Carolina
    Ram Year:
    1999
    Engine:
    5.9
    I didn't check the fuel pressure at the rails but the truck would not idle without throttle and it would still have erratic revs. I looked over everything I had messed with while messing with the dash and my terminals were pretty corroded. Cleaned em up, replaced terminals and added the foam pads, and that solved the problem, truck ran flawlessly. I would check this before anything else since this would be a relatively cheap repair if it's the problem. Report back with findings! lol
  7. pwebyd90
    13
    Feb 7, 2015
    Ram Year:
    2001
    Engine:
    5.9L magnum
    Cleaned the battery up nice and shiny, didnt change anything.. multimeter had good readings. Its been too long and too stressful, so I finally had it towed to my mechanic. Hopefully we'll know whats going on tomorrow :)
  8. MagSport
    22
    1,256
    499
    Mar 10, 2014
    South Carolina
    Ram Year:
    1999
    Engine:
    5.9
    Have you found out anything?
  9. pwebyd90
    13
    Feb 7, 2015
    Ram Year:
    2001
    Engine:
    5.9L magnum
    My mechanic said the previous owners must have cut my CEL, so thats great =/
    Only thing he can guess is bad ECM.. sound plausible at all?
    He said when he hooks it up to his scanner its not showing the computer at all, and he tried unhooking sensors to try and get it to throw codes and its not doing anything.. someone suggested crankshaft position sensor, but he said since it starts its not lack of spark or anything of that nature.. cheapest computer I can find is $217 :(
  10. pwebyd90
    13
    Feb 7, 2015
    Ram Year:
    2001
    Engine:
    5.9L magnum
    Which fuse is responsible for powering the OBDii port? That may be the problem, but cant find which fuse it is through googling =/
Share This Page
