Fuel Pump & Gauge
Discussion in 'Tech Info' started by boujie1, Sep 30, 2016.
  1. boujie1
    boujie1 Junior Member
    46
    Sep 27, 2016
    Ram Year:
    2006
    Engine:
    I had a fuel pump assembly replaced by my local shop on my 06 Ram 1500. Filled the tank after the install the gauge stopped at 3/4 and then about 5 minutes later it slowly starts to move to full. Took it back to the shop and they put a different Mfg. pump in. Still the same thing. Took it back a third time and they manually worked the sending unit while watching the gauge and they tell me it works properly. They put it back in the tank and still doing the same thing. Any idea what could be causing this?
  2. SilverStreak88
    SilverStreak88 Senior Member
    3,951
    1,583
    Jul 20, 2015
    Houston, Texas
    Ram Year:
    Engine:
    5.7 Eco Gasser
    I know this is thread is months old, but I had similar issue with mine. Mine has now started working correctly, but it took 6 months. I think its these cheap AM fuel pumps, the resistance doesn't register.
Share This Page
