Fuel system
Moparkid
La small block 318
Hello ramforum. a while ago i pucked up an 87 w100 as a project, trying to get it back on the road in time for me to get my license. a few issues have been sorted, however there is a fuel system issue. the lines are rusted out, and the throttle is a bit sticky at times. where can i track down a fuel line kit that will have the lines from the tank, up to the mechanical pump? quick searches on the interwebs havent found much, so i decided to sign up here and ask the experts.
Thanks for the help
~alex
crazzywolfie
under the truck
there are no fuel lines kits. you will have to make your own. you can get steel fuel line from parts store for about $20 per roll plus you will need a bit of rubber fuel line and hose clamps to connect things up. should need 1 roll of 5/16" fuel line for the feed line and 1/4" for the return line. could try oiling the throttle and linkage attached to the throttle.
rusties93LE
360 magnum
I would do the flexible lines, more money, but less headache putting them in!
