fuel tank help
Discussion in 'Tech Info' started by reek, May 14, 2015.
  1. reek
    reek Senior Member
    926
    342
    Nov 23, 2014
    Sacramento
    Ram Year:
    2015 RAM 2500 CC 4x4
    Engine:
    anyone know of a source for a new gas tank? This is for a short bed 75-80 (and I assume Rams up to 83) truck. I need a new tank, no one sells them. All the pick and pulls around here perforate their tanks as soon as they get the vehicle to drain them. Such a waste.
    Any help appreciated.
  2. RonJon '06
    RonJon '06 Senior Member
    3,304
    1,047
    Jan 2, 2014
    Southern Minnesota
    Ram Year:
    2006, 1985
    Engine:
    5.7, 360
    Can you salvage a tank from one of your other trucks? I was reading online that the width of the different sized tanks should be the same for those years, just the length might be a little different. Also, if the plastic tank is cracked I guess you can repair it.
  3. crazzywolfie
    crazzywolfie Senior Member
    14,096
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    maybe you could see about finding a plastic welder. they should probably be able to fix it for you. could also see about trying to find someone parting out a truck.
  4. reek
    reek Senior Member
    926
    342
    Nov 23, 2014
    Sacramento
    Ram Year:
    Engine:
    out of the 3 trucks I have 2 are in-cab gas tanks and my 78 is missing its tank. my 72 was the original project and the 73 and 78 were donor trucks. now that I've taken a close look at them the 72 and 78 are salvageable. So I now have 2 projects going instead of one. Please no one tell my wife...
    so I'm trying to piece together a 72 stepside and the 78 regular side (is it called fleetside?) shortbed. I'll probably have to go custom fuel tank from the looks of it. Or I could just recheck my sanity...
    thanks for the responses so far.
Share This Page
