full service oil thread?
dropkicknick
el paso
i might be losing my mind but i swear i saw a thread with OEM and alternative oils for full range service. engine, TC, Trans, etc
EDIT: guess i was wrong, was hoping to make this easier finding the correct oils etc but it's about time for a good old fashioned tune up. My ponies are running free 1 by 1 leaving me in the mud
ANYWAY heres my parts list in case anyone in the future stops by to take a look if you see "ALT" that means it's an alternative to oem
and of course feel free to share opinions on what could be changed. i tried to make my list as cost effective as possible without sacrificing to much quality.
vehicle specs:
2012 5.7 hemi
65FRE 6 speed trans mission
BW44-44 Transfer case
4x4 sport
-Transmission fluid
mopar ATF+4 68218057AB
Location RockAuto
price $5.66 per qt
QTY 7
-Transmission filters
Mopar
Internal filter= 5013470AE
O-ring for int filter= 4799964AD
External filter= 5179267AD
ALT WIX 58843
location Amazon
Price $32.78 kit
QTY 1
-Transfer Case oil (was difficult to find online)
Mopar BW44-44 oil 68089195AA
Location https://puredieselpower.com/dodge-products/transfer-case-fluid-68089195aa.html
Price $25.15 qt
QTY 3
-Coolant with HOAT 50/50 mix
MOPAR 68051212AB
Location Rockauto
Price $11.31 gal
QTY 4
-Spark Plugs
NGK4469 (#LFR5AIX11)
Location Rockauto
Price $2.98 ea
QTY 16
-Air Filter
K&n 33-2247 (i would give the mopar # if only they knew what it was)
Location Amazon
Price $60.99 ea
QTY 1
- Engine oil Filter
Mopar 4884899AC
ALT K&N HP-1017
Location Amazon
Price $9.98 ea
QTY 1
-Drive Belt
Mopar 4593852AB
ALT GATES K060795
Location Rockauto
Price $18.14 ea
QTY 1
-Rear diff oil
Conventional rear diff MS-8985
Limited-Slip Rear Axles require the addition of 5 oz. (148 ml) MOPAR Limited Slip Additive
ALT Red Line 57104
Location Amazon
Price $18.27 qt
QTY 3
-Engine Oil (to each his own, pick what you like as long as its API Certified SAE 5W-20 Engine Oil)
Mobil 1 full syn 5w-20 High mil
Location Amazon
5 qt bottle price $34.97 ea
Location Autozone
two 1 qt bottles $10.49 ea
Ramnewbie
please tell me i saw it, my amazon and rockauto cart is getting a little expensive with all these mopar labels
I don't know if it will be any cheaper but check out "sythetic oil" thread. Tons of info.
Sent from my XT1650 using Tapatalk
dropkicknick
dropkicknick
el paso
for some reason i cant find the OEM part number for the 65RFE 6 speed filters. mopar.com only lists a flex plate. anyone have it written down somewhere?
dropkicknick
dropkicknick
el paso
yea i was slowly going through it. alot of weeds to cut through. i have like 10 windows open right now trying to find part numbers and oils
dropkicknick
dropkicknick
el paso
found the part numbers just as i got the notification for your comment lol thank you
dropkicknick
dropkicknick
el paso
5179267ac
do you know the difference between "AC" and "AD"? because the one i found is 5179267AD. i love my truck, i swear i do but sometimes i just want to light it on fire and roll it down a hill....
and for the love of odins beard why are the 1000 mopar websites. there all slightly different and its killing my grove with these random part numbers. i thought i save the mopar number for the bw44-44 oil but after putting it into the search bar it turned out to be a turbo charger bracket.....
edit: nevermind about AC and AD, there just superseded parts
dropkicknick
dropkicknick
el paso
went to amsoil website, put in my trucks info and it says they have a product for the bw44-44 TC for $10qt.
is this snake oil or did someone actually make an alternative oil for the bw44-44?
Edit: they have the same product listed for the TRANS 65FRE, TC NV243, TRANS AP4, and BW44-45. me thinks its wrong. my super special 44-44 dosent share well with other
Ramnewbie
I've used Amsoil fluids for years, engine oil, gear lube, trans oil, never had any issues. Seems like most are using either Amsoil or redline fluids. If you have any questions or concerns you can contact them directly and ask about you're specific situation.
yortnodnarb
Adrian,MI
I wouldn't buy 3qts of t-case oil unless you want a quart and a half of left over fluid on the shelf....
