I built my truck not the dealer. The only time it see's the dealer is for all these stupid recalls. My son and I fixed it ourselves. We tried to drop the tank but couldn't figure out how to unconnect the fuel lines. We got the tank low enough to unconnect the fill tube then siphon out about 18 gals of the mix. Then drained the rear filter and cycled the key on and off a buncha times to pump out the rest. Installed a new rear filter and put in some motor oil and fuel additive with 20 gals of new fuel. Runs bitchen.
Unless you work for the assembly plant, you didn’t build your truck.
Anyway to your issue, you should be fine. Every month or so we get a diesel in that’s been filled with gas. Very rarely do we actually have to drop the tank. We run the fuel pump to pump out the gas, put some diesel in it, pump that out, change the fuel filters then fill it with diesel, and send it on it’s way. Never see them come back with any issues. Been doing it that way for the past 10 years.
Yes it’s true gas in a diesel can be very troublesome, but as long as it’s not run for long with a gas/diesel mix there shouldn’t be any long term issues.
