Gas tank strap broke
bassslayer25
East, Kansas
5.9 360 V8
So as the title states, one of my gas tank straps has finally rusted off. How concerned should I be that I only have one now?
jsmith
Very. I know one of the last things I'd want to fall off the truck at speed is a tank full of gas. And if one was rusty enough to fall off the other probably isn't too far behind it
crazy_luck
Minnesota
When I had the fuel pump replaced on my '99 1500, about a month later one of the straps broke while driving home from a local trip. To be on the safe(r) side, I pulled over and used a ratcheting tie-down strap to support the tank where the broken strap was. Held just fine for nearly a month (had to order it from NAPA and they sent the wrong one 4 times). Just refrain from off-roading or pulling Chevys out of the ditch until its properly fixed... ;)
saintsreturn
Home in St. Pete, FL
2015 Longhorn
EcoDiesel
Get one on order. You don't want to have the second one fail while you decide the next move. If one is rusted, the other should be too.
jsmith
I've noticed them on ebay pretty cheap, iirc $30-40 for the pair
Sleipnir
Magnum 5.9
LMC sells them now too.
One of my straps broke over the weekend. Just ordered a pair from LMC. I love that catalog. Seems like they have everything in there.
Is anything else holding up the gas tank besides those two straps?
Neil
  1. There’s a recall on my 2012 1500 outdoorsman on the front fuel tank strap
Gr8bawana
6.7 CTD
Rockauto $21.89 for both straps.
mmcquinn
