good wax for Brilliant Black Pearlescent paint job...
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
best way to hide scratches is to buff them out :) :hidesbehindsofa:
TexNorseman
TexNorseman
2018 Lonestar Edition with Black Out Package
Shadow agreed , I have used Scratch X with some moderate success so far, but I'm looking for something that helps protect the paint from future scratches, and maybe some tips to help preserve the paint. First time ever owning a black vehicle with metallic flake in it. :p
Also what are you guys using to dry your truck once you have washed it? Microfiber towel? I hear chamois isn't a good idea on black paint. I have also read of using a leaf blower?
shadowhawk
Southeast WI
chamois isn't good regardless of the color. go hang out in the detailing section for a while, then come back and ask questions. There's lots to read there
Burla
2010 Hemi Reg Cab 4x4
Clay your truck a lot if that is what you are worried about, up to 4 times a year. Stay away from micro fiber, better off with the Absorber or even a chamois. Fillers don't really work. Wax is a double edge sword, when the dust collects on it you can actually get swirls when you are washing it off. Sealant like zaino, a good washing procedure with a lot of suds, and good drying procedure.
TexNorseman
TexNorseman
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
The detail section on this forum will give you a wealth of information about the care of your paint. That being said, most scratches in your paint occur because of poor wash techniques. Make sure you are using the 2 bucket method. You can use "fillers" to fill the scratches instead of polishing them out, however if you use the fillers the scratches will just reappear after a couple of washes. Once you polish the scratches out, I would recommend using a quality sealant on your paint. The reason for this is that a sealant will last for about 6 months, whereas a good quality wax will only last about 2-3 weeks. You can top a sealant with a wax for extra protection and a little extra "pop" and depth. Everyone has their own favorite products. I would recommend going to autopia, which is a professional detail site and look at some of the products that professional detailers use. You can also buy a variety of products there also. Adams is also a vendor on this site and a lot of members like their products also.
Here is an excellent towel to dry your truck without worrying about leaving scratches and you only need one towel for the whole truck. I have used this towel for a couple of years and wouldn't use anything else.
https://www.autopia-carcare.com/pfm-drying-towel-griots-garage.html#.WmvWKq6nGG4
If you have any additional questions you might go to the detail section and we'll try to answer any question you have.
Jay
shadowhawk
Southeast WI
I'd wager that 98% of detailers around the world will disagree. Chamois have ZERO buffer to take contaminants away from your paint; they simply drag it along. great microfiber cloths are invaluable to a detailer
Shadow thanks for the link and the awesome info in it! Never clay barred a vehicle before, is it tedious work? Also is it easy to mess up your finish if you have never done it?
clay is relatively safe as long as you don't drop it on the ground and immediately put it back on your paint. you either toss it out and start with a new piece, or you risk scratching the paint.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
^^^^ Use lots of clay lub
Jay
Jwithing
STL
Do yourself a favor and have it professionally done, then get it ceramic coated. Best decision and money I ever spent. Now I get to keep my brilliant black clean by running through a car wash and not worrying about the swirlies!
blackbetty14
CT
Hemi 5.7 VVT/Etorque
Clean well, clay bar and then prob a ceramic coat. I don’t like the ceramic coat and I prefer to use a self applied long lasting coating.
Here’s what I’m doing currently.
Foam cannon with chemical guys melon cannon foam. Then wash with a micro fiber mit, then seal with chemical guys top coat or jet seal. After the initial sealing you repeat the same foam cannon to get all the crap off the truck and then mit wash to clean it and then hit with your favorite short term wax which will be Adams buttery wax (new formula).
For your initial wash/seal you should prob clay bar before the seal. Unless the truck is brand new and the paint is clean.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
IMHO---most "brand new trucks" are usually not "clean" and still need to be clay barred. A lot of them have rail dust and other contaminants on the surface from shipping. There may be some exceptions however. Don't assume that the dealer did a good job cleaning your new truck. They probably did more damage to the surface than they helped. Do the baggie test to find out if you need to clay bar.
Jay
rstang98
A good quality polish and then a sealant like Klasse AIO will do wonders
Burla
I was a detailer for 4 years as a business owner until I graduated college, we used to have a club online the detailersclub, know defunked I guess. Many detailing supply manu's still try and contact me, know them personally. The issue with MF is when it picks something up it keeps it. Any grit at all and you wont know til the swirls are in. I agree we used MF ever since it was first invented and is a great tool, but for drying cars many of us prefer air or absorber type dryers. To each their own, I am aware a lot of people use MF.
TexNorseman
TexNorseman
I have an absorber that I occasionally use, but it appears to leave streaks, do I need to buy a new one Burla?
Burla
wash it in dawn soap, rinse with hot water, or get a new one.
AdamsPolishes
Preferred Vendor
A shiny one
Check out our Clay mitt, it does a great job and it's fast.
