Griding
Discussion in 'General Discussions' started by nussdawg395, Feb 13, 2012.
  1. nussdawg395
    nussdawg395 Senior Member
    33
    625
    May 27, 2011
    PA
    Ram Year:
    2002
    Engine:
    5.9 Magnum
    So on my way home from work today my truck made a hell of a grinding noise like bearings destroying. It actually made the truck jerk and seem like something was binding. I just replaced my wheel bearings in October. I'm thinking its this and i got a faulty one. If i can get a vid i will but it was so random it happens and i got the "WTF was that" thing going on and couldnt quite pinpoint the noise. It went away and drove perfectly fine, then about 500ft down the road i was going around a small turn and it started screaming again. Then the rest of the drive (about 5 miles) it was fine.
    Cant get it in the father in laws garage till at least wednesday.
    Any ideas i should look for past wheel bearing.
    Oh and new U-joints last summer, greasable type, ill def give them another shot too.
  2. rambob
    rambob Senior Member
    1,595
    27
    Aug 15, 2011
    LA/MS
    Ram Year:
    2001
    Engine:
    318 5.2l
    while turning only? - rear end
  3. nussdawg395
    33
    625
    May 27, 2011
    PA
    Ram Year:
    2002
    Engine:
    5.9 Magnum
    First time it did it was on a straight right after a turn. Second was on a slight turn both rights. I def. have to crack the rears open and take a peek there too. Might be a good time to do so.
  4. ramfanatic
    ramfanatic Banned
    Feb 5, 2012
    could be wheel bearings going bad
  5. nussdawg395
    33
    625
    May 27, 2011
    PA
    Ram Year:
    2002
    Engine:
    5.9 Magnum
    Thats exactly what it was passenger wheek bearing. I've never heard a wheel bearing sound like that, but i took it to a garage (my uncle works there and gets full personal use on weekends and parts for cost) and put it on the lift, sure enough wheel bearing was bad. While i was in there i threw on new brakes and rotors and now all is well.
  6. bigbadram1500
    bigbadram1500 Administrator Staff Member
    38
    15,293
    583
    Jul 7, 2010
    Springfield, IL
    Ram Year:
    2008
    Engine:
    Just last night, I felt the same thing in my truck, it wasn't a noise persay, but more of a grinding feeling. Both times the truck was in a slow turn. Might need to check mine out too.
  7. Trupiano
    Trupiano Registered User
    33
    10,982
    667
    Jun 27, 2010
    Hometown : Puyallup,WA Stationed : Little Rock,
    Ram Year:
    2010 Ram 2500 6.7L CTD Crew Cab
    Engine:
    6.7L CTD
    Aw crap, the wheel bearing flu is spreading!
  8. truckin151
    truckin151 Supporting Member
    5,711
    230
    Ram Year:
    2013 sport
    Engine:
    Noooooooo!!!!!!! Not the wheel bearing flu. I just got over the timing belt flu and the traction flu, you all need to stay far far away lol
    Mine made that sound too. Wasn't a bearing though, it was the alignment tab on the front passenger wheel. The tab was sticking into the header. Trimmed it up and no more grinding
Share This Page
