guages pictures
Discussion in 'Interior' started by Redtruck-VA, Nov 3, 2014.
  1. Redtruck-VA
    Redtruck-VA Senior Member
    5,372
    692
    Virginia
    Ram Year:
    2003 & 1989 D250 RWD
    Engine:
    Hey guys I'm new to the 1st Gen world, post up some pictures of how your gauges are mounted. Also how do you remove the center panel in the dash?
  2. RonJon '06
    RonJon '06 Senior Member
    3,306
    1,050
    Jan 2, 2014
    Southern Minnesota
    Ram Year:
    2006, 1985
    Engine:
    5.7, 360
    Do you just want a pic of the dash from the outside or do you need one of what's behind the panel cause I dont have one with the panel off.
  3. Redtruck-VA
    5,372
    692
    Virginia
    Ram Year:
    Engine:
    I'm thinking of putting two or three gages in the center panel. So pictures showing gauges mounted and a little information on how to disassemble it would be great.
    Thanks,
  4. RonJon '06
    3,306
    1,050
    Jan 2, 2014
    Southern Minnesota
    Ram Year:
    2006, 1985
    Engine:
    5.7, 360
    This isn't my truck since it's still stock but I found this in a search and thought it looked pretty clean. I looked for a DIY to go along with it but didn't see one.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    youkmc, bozeblake and Redtruck-VA like this.
  5. Redtruck-VA
    5,372
    692
    Virginia
    Ram Year:
    Engine:
    That looks awesome. Dumb question, how is the say radio or center panel removed from the dash?
  6. RonJon '06
    3,306
    1,050
    Jan 2, 2014
    Southern Minnesota
    Ram Year:
    2006, 1985
    Engine:
    5.7, 360
    That I don't know. It kinda looks like he just cut it out.:superhack:
    This is what mine looks like. The rectangle on the left is for the 4WD indicator light, cubby hole on the right and radio underneath.
    [​IMG]
  7. Redtruck-VA
    5,372
    692
    Virginia
    Ram Year:
    Engine:
    I guess I'll have to pull the front and then make the insert plate(s). I'll probably remove the radio while I'm at it. Maybe have a spare dash face to work with and then just swap.
  8. crazzywolfie
    crazzywolfie Senior Member
    14,101
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    here is the gauges i got on my truck. voltage, engine temp, tach, vacuum and out door temp. stock gauges suck for the most part.
    [​IMG]
    [​IMG]
  9. Redtruck-VA
    5,372
    692
    Virginia
    Ram Year:
    Engine:
    Yes, I'm thinking tach, boost, fuel pressure, egt. I specifically want a 0-3500 3-3/4" tach. I want to put it on the steering column. I've found a couple that use a flywheel pickup, but don't know if the harmonic balancer pickup will be a good substitute or is there a mounting arrangement that can be used with the flywheel pickup.. I think our flywheel(flex plate) is 152 teeth.
  10. crazzywolfie
    14,101
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    ya i don't know much about that. i am use to dealing with a gasser lol. i am pretty good at making stuff work tho. i got a overhead console out of a 93 jeep Cherokee in my 93 and a OHC out out of a 93 caravan in my 81. if i can get some decent led light for the 98 caravan OHC that will be going in my 81 but having a hard time finding good leds for a weird light setup.
Share This Page
