Hard starting after sitting for the winter
Discussion in 'Engine & Performance' started by svdsinner, Mar 20, 2017.
Sponsored By: Moe's Performance
  1. svdsinner
    svdsinner Junior Member
    46
    17
    Oct 19, 2016
    Ram Year:
    1998
    Engine:
    5.9L V8
    My '98 Ram 2500 5.9L V8 has been a reliable starter and runner since I bought it last spring. This last week, it has decided to become very difficult to start, and I thought it'd be a good time to get some sagely wisdom from you guys.
    The engine cranks fine, but takes a long time to get it to fire at all. If I can get it to fire at all, it starts up immediately. It now runs badly (die if you didn't gas it) for the first minute or two until the engine warmed up a bit, and then everything runs great.
    Here's some recent history:
    1) It burst a brake line 3-4 months ago and sat until I recently had a chance to fix it. Was running fine at that point.
    2) After I replaced the brake lines, it wouldn't start initially. I saw the gas gauge was on E, so I added a gallon from a gas can, and it reluctantly started in 15F weather, and needed me to feed it gas to keep it from dying for a minute or two.
    3) It started, restarted and idled just fine while I was bleeding the brakes.
    4) This evening, she wouldn't start at all. Cranks fast, but no fire. Added another gallon of gas. No improvement
    5) No check engine light.
    6) I checked the air filter. It was dirty, but more importantly, had a mouse nest under it, and had a big circle where the mouse had chewed up the filter to make the nest. No rodent corpses in the air line. Not sure if bits of filter could've been sucked into the engine. (Or if an engine would have any issues with passing/burning bits of filter paper)
    Next time I get a chance, I'll check the 3 basics: Fuel, Spark, and Air.
    1) Fuel: What's the best spot on the 5.9L to pull the fuel line and check that fuel is flowing? Can I also assume this engine could benefit from starting fluid in the air filter?
    2) Spark: If I don't find the issue with #1, I'll buy some new plugs and wires. Does the 5.9L gain anything from nicer plugs and/or wires? Or are OEM equivalents just fine?
    3) Air: I'll be replacing the filter and probably adding in a bit of aluminum window screen as a prefilter/rodent guard. Not much else I can do here.
    This is my first time playing with a 5.9L. Any wisdom from the trenches is appreciated if there are any peculiar issues of the 5.9L that might be relevant here.
  2. goodtodoo
    goodtodoo Senior Member
    130
    13
    Jul 17, 2016
    Ram Year:
    1996 indy pace truck
    Engine:
    5.9
    Never use starting fluid on a gas engine. Have you tried opening the throttle with your foot during cranking, not much, just a little. Could be the TPS.
  3. dudeman2009
    dudeman2009 Senior Member
    22
    1,509
    177
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    As was stated, do not use starting fluid. A common issue on these old trucks is either the Idle air control valve or throttle position sensor.
    Just barely hitting the gas while starting should get it to start just fine if those are the problem.
    As for spark plugs, only use Copper, anything else causes problems, no matter what they guy behind the counter says. Plug wires are just wires.
    I'd also check the fuel pressure when its giving you problems one of these times.
  4. dapepper9
    dapepper9 Senior Member
    22
    4,873
    1,873
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    You can check rail pressure with the rail mounted valve
  5. yoda
    yoda Senior Member
    48
    302
    117
    Jul 25, 2016
    Ram Year:
    Engine:
    Possibly a week coil. I use an adjustable spark tester to test, it should jump the gap minimum at the 10kv mark on the tester. Or just try a new coil.
    I don't see the big deal using starting fluid on a gas motor. Diesel is where you can really get in trouble if you don't know what you are doing
  6. svdsinner
    46
    17
    Oct 19, 2016
    Ram Year:
    1998
    Engine:
    5.9L V8
    This is my first vehicle with a fuel rail valve. Do I just put an air gauge on it?
    P.S. Ive tried giving it gas with no success. I'm guessing if there is fuel pressure, then the coil went bad, if not the fuel pump died.
    EDIT: No fuel pressure. I'm assuming the fuel pump died. Is there any sane reason why new fuel pumps for this truck range from $50ish to $220? Is this a simple drop the tank and swap the pump, or is anything else required?
  7. Gr8bawana
    Gr8bawana Senior Member
    286
    71
    Dec 7, 2015
    Ram Year:
    1997
    Engine:
    5.9
    If your fuel pump is indeed the culprit I have been told it's much easier to pull the bed off the frame rather than dropping the tank from underneath.
    I can tell you from experience that dropping the tank is a PITA.
    Good luck.
  8. dudeman2009
    22
    1,509
    177
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    Engine:
    Magnum 360
    I'm not sure about the fuel pump, i've never looked one up to replace it on my truck. The cost could be everything from the mounting hardware to the sending unit to the fuel pump or the whole assembly just being labeled as fuel pump.
    As for removing it, its a toss up on pulling the bed or dropping the tank. I recently had to drop the tank on a 98 at work to fix a fuel leak. It took about 2 hours all in all and was much easier than pulling the bed. But I have lifts and transmission jacks to use.
  9. svdsinner
    46
    17
    Oct 19, 2016
    Ram Year:
    1998
    Engine:
    5.9L V8
    It looks like my vent tube is rusted in half and hanging loose. I can't spot the other side of the tube. Where does the vent tube run to?
    Sent from my SM-G920V using Tapatalk
  10. dudeman2009
    22
    1,509
    177
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    Engine:
    Magnum 360
    The vent tube traditionally runs up right next to the filler nozzle so gas stations with vapor recovery systems can capture the displaced air from your tank.
    Usually when you buy a new filler neck they come with the vent tube.
Share This Page
