Yark d
- Aug 19, 2015
- 2
- 0
- Location
- southeast IA
- 1993
- 5.9L Magnum V8
I am a new member here and FYI this is my 1st time using any forum of any kind on the internet so please be kind and helpful. I have a 93 W250 with a magnum 360. My problem at this time is the headlights. I cannot adjust the headlight buckets high enough to see further than 30 feet in front of me. I put new adjusters in several times trying different brands hopin for better quality but no luck so far. when i tighten the adjusting screw to move the headlight up either the threads in the cheap plastic adjuster strip out or the plastic clips (on the sides of the adjuster that hold the adjuster in place) break off. I have tried to hook the spring differently to have less pressure against adjusters but never any success yet. This problem is the same on both headlights and has existed since i purchased the truck 3 years ago, but recently got worse. Any hope, ideas, or thoughts would be appreciated. also i would really like to stay away from any crude ideas if at all possible. I have another issue, the headlights cause a hot wire smell in the cab after being on highbeam for a few minutes. I have replaced both lights and pigtails to verify that was not the problem and no change. I am wanting to order a Headlight harness from LMC Truck but without being sure where the problem lies I am hesitant at this time. Any common problems with this out there or ideas?
