Help with rust-proofing my truck
Usafparker18612
Charleston AFB
I need some tips on rust proofing the undercarriage of my 2003 1500. I already have the truck bed taken off and I've stripped a lot of the frame down to bare metal (I used a wire wheel/abrasion wheel. I don't have a sand blaster at my disposal.) But there are still a few spots, like inside the frame and tubing, that has some minor surface rust.
I plan on hitting the truck frame with some tar and wax remover and then some acetone to break up any dirt/grim/left over rust and then hit it with a couple coatings of rusty metal primer. After the primer has dried, I'm gonna hit it with Rustoleum undercoating from a spray can.
This is honestly the best I can do right now with the amount of time and resources I have (Average day, I get about 3 hours of daylight to work on it and I have to work on it outside :(
If anybody has anymore tips they could chip in to help out with the finished product that would be much appreciated.
Stangshcky12
Oshkosh, WI
5.9 Cummins
For the work you have into it I would try to use por15 instead of the undercoating
My next choice would be herculiner, for the the places you can't get the rust try to spray with an etching primer that will stop the rust from spreading once painted over and only use the spray can undercoating/Bedliner for places you can't get with a brush/roller
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
they sell it at the auto paint store that my painter works at.
Stangshcky12
Oshkosh, WI
5.9 Cummins
I've seen it at car quest before, I would try calling around your area
Usafparker18612
Usafparker18612
Charleston AFB
I'll look for it. But would I be able to use the undercoating I have now and eventually apply the POR15 over the undercoat without any more prep work (besides washing off any dirt) Or would that get too heavy? And could that POR15 be used on the leaf springs?
