Thanks guys!!!
I'm in the same position with tapping into fuse F79 but what if a guy wanted to tap directly into the wire underneath for a super clean install? Does anyone have any wiring diagrams or knows what wire to tap into? I poked at a couple wires but couldn't find the right one
No I only have a 1500 but there is power to that fuse. It looked like there was a wire coming off but maybe not.Unless you have a 2500 or larger, there won't be a wire there. You will need to add a pin/wire to socket 26 on the C7 connector under the TIPM. That's how I did mine.
-K
I wound up tapping into the headlight.
What is the Fuse 79 y'all are referring to? On my classic 1500 is listed as clearance lights, which I'm going to try tapping into for marker lights myself, but wanted to clarify if that's what you guys were referring to.looks great, that F79 really comes in handy
