Hood Vent LED
ToxicFire
CA
old thread bump but hoping to do this in the next couple weeks.
Some have done plug and play and say it connects to factory harness for turn signals/ daytime lights . On a 14 sport with projection style lights what would i tap into?
Do i need inline fuses? I have a small 6 fuse box im using for other led bar install i could use if needed.
Also anyone ordered from amazon have links to good 5mm bulbs,white and amber?
do i drill 5mm holes?
Rebelrouser
Cowtown AB
'22 Ram 1500 GT
No fuses are needed. When I did mine I just hard wired the middle row(amber) to my signal lamp wires- each side. For the top/bottom rows I wired them to the park light wires-both sides. Easy peasy- japaneesee. But, I also wired in waterproof 3 pin connectors that run down beside the battery area- same distance on both sides so as to not make it look like a monkey wired it. That way if I had to remove them it's real easy. Just pullthem through the hood vent hole.
